Re: Proforged Greaseable LCA Pin Kit
[Re: AlexP]
#2104219
07/05/16 01:43 PM
07/05/16 01:43 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If it's a simple difference like that it should be easy to fix. I can understand the disappointment with a non-fitting new part.
If your old ones are still serviceable they can likely be drilled for grease fittings.
[Re: AlexP]
#2104506
07/05/16 09:59 PM
07/05/16 09:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I believe they are made to NOT use the inner shell, the poly bushing rides right on the pin. So the PF pin would have a larger diameter than stock.
[Re: 68rrunner]
#2127833
08/08/16 01:51 PM
08/08/16 01:51 PM
Posts: 321 Massachusetts
Sneke_Eyez
Massachusetts
I'm thinking of trying Bergman's Delrin on my Wife's DD on this years teardown service. We've had the Polys in the there for some time and I wasn't liberal enough with the grease when I installed them, so the car is super creaky. My UCA bushings are super creaky like that even though they're the rubber ones. It's an annoying noise. Missed getting to chat with you at Carlisle this year, Dan. Might have the wagon there next year.
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe. 2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast? Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com!
