trans blanket suggestions? #210303
02/01/09 09:58 AM
02/01/09 09:58 AM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
I am thinking about adding a trans blanket to my 727 equipped small block A body, anybody have any thoughts pro/con? Who makes good one, who makes cheap one. What fitment problems are there? Car is low 12s, no brake, 3600 converter, 6800 rev limiter. I did loose a drive shaft on 2800 rpm launch last run in ’08.
Thanks for any comments!
4bbl If you can't hear it coming what's the point.......
Re: trans blanket suggestions? [Re: 4bbl] #210304
02/01/09 10:09 AM
02/01/09 10:09 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I would go with a shield instead. The reason? .. the blanket holds-in-heat...will "wear out" and soak-up ATF and oil.
Re: trans blanket suggestions? [Re: 4bbl] #210305
02/01/09 10:37 AM
02/01/09 10:37 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I would check the overunning clutch. There is a guy called Chuck Lofgren ( I think thats the right spelling) that sells blankets for the mopar stuff. Its what I have and it took less than a 1/2 hour to install.
Re: trans blanket suggestions? [Re: 4bbl] #210306
02/01/09 10:45 AM
02/01/09 10:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.lofgrenautospecialties.com/view/transmissions_2.aspx
Scroll down the page a bit for picts. These blankets fit plain and simple and you can order them SFI approved if needed. Chuck is a good guy
Re: trans blanket suggestions? [Re: J_BODY] #210307
02/01/09 10:46 AM
02/01/09 10:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
This is the only pict I have of mine...
