Re: 440 Swap
[Re: Rumblefish]
#210288
02/01/09 09:56 AM
02/01/09 09:56 AM
moparpollack
Lil Herman
Lil Herman
85086
Nope, two different transmissions.
Re: 440 Swap
[Re: buildanother]
#210289
02/01/09 10:02 AM
02/01/09 10:02 AM
Posts: 1,394 Long Island, NY
Rumblefish
Long Island, NY
No. need big block case. I'd stuff a stroker small block in that black monster.
That was actually the original plan. The thing is that I can get this 440 from my uncle for a really great price, and it is completely rebuilt. It would cost alot less than doing a stroker small block. What do you guys think?
So now that I know I cant use this trans, do you guys think this would still be a good swap if I can get the right transmission and have it rebuilt?
Tom
Re: 440 Swap
[Re: buildanother]
#210291
02/01/09 10:41 AM
02/01/09 10:41 AM
Posts: 910 Southern Oregon
toyotajeep
Southern Oregon
I'm doing this swap on a 74 soon.
Two things:
Go to the Schumacher website Engine swaps .com or something And.....Check out Big Block Dart
That will get you started.
ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: 440 Swap
[Re: RapidRobert]
#210294
02/01/09 11:01 AM
02/01/09 11:01 AM
In my opinion, you should stay SB. If you want more power, sell the 440 and use the money toward a 360 build or something. You'll have to change a LOT of details in the gorgeous little car, already all set up for a SB. Wiring, exhaust, possibly rad / rad mounts, on and on.
Re: 440 Swap
#210295
02/01/09 02:05 PM
02/01/09 02:05 PM
DaytonaTurbo
Manitoba, Canada
If you want big block, go for it. engine-swaps.com has your motor mounts and TTI has your headers. IIRC, the TTI headers will only clear for manual steering, not power steering, but check out their website to confirm. Kinda a waste of a small block 727 but if you're married to that trans you could cut the bell housing off of it and bolt on a jw ultrabell, although I would sooner buy a BB trans and rebuild it on the side so you could keep driving the car for a while yet. Then depending on your rad, if may or may not need an upgrade.
Re: 440 Swap
#210296
02/01/09 02:07 PM
02/01/09 02:07 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Getting a big block tranny case will be easy. The headers you need will be expensive.
Keep old mopars alive.
Re: 440 Swap
[Re: RapidRobert]
#210299
02/01/09 10:16 PM
02/01/09 10:16 PM
Rumblefish
Long Island, NY
I am still on the fence about this whole thing. I wanted to do a 408 stroker but the deal on this 440 is sweet. Tom
When I had my BB duster it scared me when I got on it
Thats why I want that 440
Re: 440 Swap
[Re: RapidRobert]
#210300
02/01/09 10:22 PM
02/01/09 10:22 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Once you get the 440 in, your doubts will be gone.
Putting a big block in an A body isn't exactly a new frontier.
Lot's of mounts available some info at big block dart.com too.
The wiring changes are very minimal. The alternator, oil, temp senders are almost all in the same spots.
Depending on coil mouning, the coil +/- , and the points wire (or dist pu leads) are really your only wiring mods.
