Oiling holes line up...where??? on 273 trying to prime
#210183
02/01/09 01:37 AM
02/01/09 01:37 AM
Posts: 460 Kentucky
Greencospeedshop
Kentucky
Trying to get oil up to the rockers....I have it everywhere else. I tried all 4 quardants.......tdc,90,bdc,90... nothing ... I even tried straight up and down in relation to the crank centerline.... and at a 90 to it as well.... I have done this before and sucessfully....can't seem to strike oil now though.... Nothing on it in the 1969 or 1970 Chassis service manual... I know someone out there knows this.... Thanks. GCSS
Officer to me... "I had my pedal to the floor and you were still pulling away like a rocket!"
Re: Oiling holes line up...where??? on 273 trying to pr
[Re: Dodgem]
#210186
02/01/09 09:10 AM
02/01/09 09:10 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Before my SR heads that oil through external lines I would spin the motor over with a kicker button clipped on to the start relay as I run the drill clockwise SB and counter clockwise. That seems to be the ticket
counter clockwise BB sorry. or have some turn it by hand as you prime or turn little bit at a time But there may be an exact spot??
[Re: MoparforLife]
#210189
02/01/09 12:27 PM
02/01/09 12:27 PM
RapidRobert
I'd grab a helper & have him turn the crank slowly w a breaker bar(take plugs out) while you man the drill(CW)
Re: Oiling holes line up...where??? on 273 trying to prime
[Re: Greencospeedshop]
#210190
02/02/09 05:54 PM
02/02/09 05:54 PM
Posts: 460 Kentucky
Greencospeedshop
Kentucky
I am using stock 273 heads. I turned the crank quite a bit and no oil. I do have the rocker shafts correctly located. I will have an assistant turn the motor over slowly while I run the drill. I am doing all this BEFORE I install it. I am asking if anyone knows at exactly what point (degree) do the oiling holes line up ?? If I don't get oil, I will pull the cam out to check and be sure the oil holes are exposed. Thanks. GCSS
[Re: Snoopy]
#210196
02/02/09 08:28 PM
02/02/09 08:28 PM
You don't need all this about the degrees. If you can't get oil by spinning the pump and either wrenching or cranking the engine with the starter, you have a problem. Either you have something basically wrong in the pump path--plugged passage, etc, a missing plug, etc
[Re: Magnum]
#210198
02/03/09 12:33 AM
02/03/09 12:33 AM
RapidRobert
What about your other cam bearing? On a SB the #2 & the #4 cam bearings have 2 holes to direct oil topside rather than just (1) cam bearing for BB's. If your other one is dead on like the one in the pic(I would think it is since that one is good), & you have checked your rocker shaft alignment & if your turning the crank slowly by hand(& I'm thinking you are) that pretty much leaves a problem with the head gaskets blocking the(2) holes on each bank.
[Re: dart4forte]
#210200
02/04/09 02:05 AM
02/04/09 02:05 AM
Posts: 460 Kentucky
Greencospeedshop
Kentucky
engine is on the stand... What plugs?? I am out of town right now and can't do anything till Saturday.. I will have an assistant help and also look at the plugs.....But are you talking about the ones that are behind the frost plugs???
#210202
02/04/09 02:38 AM
02/04/09 02:38 AM
RapidRobert
you might take off the drivers rocker arm assy & see if you can blow some air in the passage & see if it's coming out at the #2 cam journal, (if so) take the passenger rocker arm assy off & see if its clear to the #4 cam journal. If both are open you wont have to R&R the heads. (If not) your only out a pair of head gaskets
