Re: TF 904 Reverse Problem (Stalls)
[Re: paddel]
#2101165
06/30/16 03:24 PM
06/30/16 03:24 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's not a trans problem, it's a tuning problem.
When in Reverse the trans line pressure increases dramatically and the extra load of the pump can cause a poorly tuned motor to stall. Also, misadjusted TP cable (if it's Lokar it's probably misadjusted) can exacerbate the problem with the R to D shift.
