Re: Correct info on Flex Plates needed
[Re: blewbyu]
#2101016
06/30/16 10:49 AM
06/30/16 10:49 AM
Posts: 75,059 U.S.S.A.
JohnRR
U.S.S.A.
there is no difference in the flexplate , they are all neutral balanced , the external weighting is on the converter.
Your holes sizing is off , 5/16 or 7/16 I don't recall ever seeing a 6 bolt factory flexplate with 7/16 (hemi) size holes ... but I haven't seen every plate made for production line cars ... maybe a Direct Connection/MP flexplate has a 6 bolt crank flange and 7/16 holes ??
[Re: blewbyu]
#2101112
06/30/16 01:56 PM
06/30/16 01:56 PM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
Sounds like whoever put the trans in didn't know the converter has an offset in the pattern.
[Re: JohnRR]
#2101172
06/30/16 03:30 PM
06/30/16 03:30 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Your holes sizing is off , 5/16 or 7/16 I don't recall ever seeing a 6 bolt factory flexplate with 7/16 (hemi) size holes ... but I haven't seen every plate made for production line cars ... maybe a Direct Connection/MP flexplate has a 6 bolt crank flange and 7/16 holes ?? All 426 M.W. motors and maybe the 413 M.W motors had them with stock 11 inch converters, maybe some other later ones had them OEM like the 1969 440 A and B body M code motors, maybe not
