Re: Mallory 140 fuel pump... better choice for the $$$?
[Re: BradH]
#2099999
06/28/16 03:09 PM
06/28/16 03:09 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Aeromotive 11203 street rod pump.
[Re: an8sec70cuda]
#2100004
06/28/16 03:21 PM
06/28/16 03:21 PM
Thumperdart
State of confusion
I ran that one and it worked better dead headed than returned for me.......
[Re: an8sec70cuda]
#2100044
06/28/16 04:50 PM
06/28/16 04:50 PM
fast68plymouth
So. Burlington, Vt.
Aeromotive 11203 street rod pump. Or the 11213, which is the same thing but with 8AN fittings instead of 3/8 pipe.
[Re: BradH]
#2100112
06/28/16 07:38 PM
06/28/16 07:38 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
A dim light bulb went on over my head when it occurred to me that my almost-new Mallory 140 pump may have been sitting for years with stale E10 gas in it. I found my 140 locked up after a winter sitting un-drained. I just pulled the bottom plate off and cleaned everything up and it was fine. I also have a mallory 250 I got off that internet auction site for $50 because it was a bad ad. I figured on getting a rebuild kit but decided to try it without. I took it apart (had obviously been sitting and dirty) and soaked the gaskets/seals in gas overnight, cleaned everything up and put it back together and it's never given me any trouble. Looks great too.
[Re: BradH]
#2100144
06/28/16 08:30 PM
06/28/16 08:30 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
So, I checked the price for a new one (yes, I know they offer some type of rebuild kit, but this could be a case of internal corrosion) and was shocked by how much the price has gone up. The last pump & regulator kit was under $300, and now the pump alone looks like it's over $300.
I never ran a return line and am not set up for one. Any other dead-head style pumps that can support 650+ HP I should check into? FWIW, the rest of the setup is #8 or 1/2" line to the Mallory regulator and two #6 lines feeding the carb. I ran a Holley black setup exactly as you are on a 650 horse motor(9.80's @135, 3350 pounds, 1.34 60 foot) for years. I caved to peer pressure and installed return, bigger lines, way bigger pump( in short threw a bunch of money at the fuel system) and didn't see squat difference. Not even a hundredth. If you have good constant voltage to a Holley black, it will handle your 650 horse no sweat.
[Re: BradH]
#2100192
06/28/16 09:33 PM
06/28/16 09:33 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Pretty pleased with with my Holley HP150 I replaced my POS Edelbrock 160gph pump with. Had a couple of the vanes fail in the Edelbrock pump so I wanted get away from a vane-style pump. The Holley HP is a gerotor-style and moves fuel well for the $$. Not to mention it is much quieter than my old one.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: B3422W5]
#2100444
06/29/16 09:55 AM
06/29/16 09:55 AM
an8sec70cuda
I never ran a return line and am not set up for one. Any other dead-head style pumps that can support 650+ HP I should check into? FWIW, the rest of the setup is #8 or 1/2" line to the Mallory regulator and two #6 lines feeding the carb. I ran a Holley black setup exactly as you are on a 650 horse motor(9.80's @135, 3350 pounds, 1.34 60 foot) for years. I caved to peer pressure and installed return, bigger lines, way bigger pump( in short threw a bunch of money at the fuel system) and didn't see squat difference. Not even a hundredth. If you have good constant voltage to a Holley black, it will handle your 650 horse no sweat. I had a similar situation, but w/ the Aeromotive 11203 pump. Upgraded to the bigger A1000 pump and return system...ran no different. That was running mid 9s at 3800 lbs. The main I reason I switched was to go to a return style system which made a big difference on the street as far as keeping the fuel cooler. Plus I knew I would be adding nitrous later...needed a bigger pump to feed both the motor and the spray.
[Re: BradH]
#2100500
06/29/16 12:00 PM
06/29/16 12:00 PM
an8sec70cuda
I honestly don't see the Aeromotive as being any louder than the other style pumps I've used...like the old Holley pumps. My A1000 pump is no louder really. Now the big A2000 on the Camaro is loud. The Mallory pumps seem to be good stuff...never run one myself, but have always heard good things about them.
[Re: BradH]
#2100512
06/29/16 12:29 PM
06/29/16 12:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you isolate the pump and lines most pumps are pretty quiet... if you can mount it in the tank the fuel helps to deaden the sound... the pump I have on my injection is the quietest pump I have owned and its pretty good size and its mounted on the back area of the car/truck... I'll have to take a DB reading on it but its low EDIT When I built my tank I didnt have any plans for putting the pump in the tank(carb back then) but I sure wish I would have thought ahead... I could still do it but the pump I have now is external but I can set the tank up for a internal pump
[Re: BradH]
#2100545
06/29/16 02:01 PM
06/29/16 02:01 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I would just take the Mallory apart and clean it. maybe put a kit in it. I carry a kit with me on DW. I have had the kit since 2012 and my pump since 2003
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
