408 thrust bearing wear
#2098585
06/26/16 04:15 PM
06/26/16 04:15 PM
Posts: 76 georgia
intenseneon
georgia
Hey guys had built a 360 mag based 408, had the block line honed ect. good clearance numbers ect. Broke engine in on dyno, made pulls and it was good.Put 10 runs on engine chewed up thrust and a few rod bearings. 60 psi oil pressure when I pulled off trailer Redid engine, sent converter in to get check(nothing wrong). Trans was rebuilt last year and I ran it with no problems last year. So I redid engine after one day racing same issue.caught it In time to not get rod bearings this last time. Where else do I need to look to fix problem. Thanks for any suggestions.
69 Dart
Re: 408 thrust bearing wear
[Re: intenseneon]
#2098596
06/26/16 04:40 PM
06/26/16 04:40 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Make sure the converter hub floats freely into the back of the crank. I had one that wouldn't and took out the thrust
[Re: intenseneon]
#2098800
06/26/16 09:26 PM
06/26/16 09:26 PM
Posts: 76 georgia
intenseneon
georgia
Thanks for the responses I'm running a 904, is there anything I can check on it?, Front pump or something?, Hashing it out in my brain I might have a bit to much trans fluid in trans,i need to check that although no fluid is coming out anywhere.I have -6 an fittings for trans lines, checked for kinks and don't see any. the converter does float freely on crank, weird situation volare I hate to buy another converter,what amount of spacing do you have?. what I don't get is I was running trans with stock 360 and never had a issue. Thanks again guys.
69 Dart
