408 thrust bearing wear #2098585
06/26/16 04:15 PM
06/26/16 04:15 PM
georgia
intenseneon Offline OP
georgia
Hey guys had built a 360 mag based 408, had the block line honed ect. good clearance numbers ect. Broke engine in on dyno, made pulls and it was good.Put 10 runs on engine chewed up thrust and a few rod bearings. 60 psi oil pressure when I pulled off trailer Redid engine, sent converter in to get check(nothing wrong). Trans was rebuilt last year and I ran it with no problems last year. So I redid engine after one day racing same issue.caught it In time to not get rod bearings this last time. Where else do I need to look to fix problem. Thanks for any suggestions.
69 Dart
Re: 408 thrust bearing wear [Re: intenseneon] #2098594
06/26/16 04:39 PM
06/26/16 04:39 PM
Boise
Moparteacher Offline
Boise
Look for restriction in the transmission cooler or cooler lines. The fluid comes out of the converter and into the cooler. When there's a restriction, or simply not enough flow for the volume of fluid, it creates pressure against the snout of the converter and drives the converter into the engine creating excessive thrust wear.
A misaligned block hone can create an issue also, although it's unlikely.
The 727 torqueflite uses 5/16 cooler lines. The 518 uses 3/8 cooler lines. Upgrade the cooler lines and fittings to 3/8.
Re: 408 thrust bearing wear [Re: intenseneon] #2098596
06/26/16 04:40 PM
06/26/16 04:40 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Make sure the converter hub floats freely into the back of the crank. I had one that wouldn't and took out the thrust
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 408 thrust bearing wear [Re: intenseneon] #2098756
06/26/16 08:29 PM
06/26/16 08:29 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
I put 4 thrust bearings in my sb, had the converter checked by the place that built it, new flexplate, converter spacing, line pressure. All that and it would still eat thrusts. New converter from another manufacturer, no problems.
Re: 408 thrust bearing wear [Re: intenseneon] #2098800
06/26/16 09:26 PM
06/26/16 09:26 PM
georgia
georgia
Thanks for the responses I'm running a 904, is there anything I can check on it?, Front pump or something?, Hashing it out in my brain I might have a bit to much trans fluid in trans,i need to check that although no fluid is coming out anywhere.I have -6 an fittings for trans lines, checked for kinks and don't see any. the converter does float freely on crank, weird situation volare I hate to buy another converter,what amount of spacing do you have?. what I don't get is I was running trans with stock 360 and never had a issue. Thanks again guys.
69 Dart
Re: 408 thrust bearing wear [Re: intenseneon] #2098806
06/26/16 09:35 PM
06/26/16 09:35 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Take the converter bolts, converter should spin freely in the crank. Push the converter back into the pump, u should have around 1/8" gap between bolt lugs & flex plate .
