What do you have on your "Switch Panel" for your race car ??
#2098168
06/25/16 10:46 PM
06/25/16 10:46 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I am going to be doing some wiring upgrades. Curious what your panel control functions are on your Switch panel...
I have plans for the usual,,eg, Start, Ignition, Fuel pump, electric fan, water pump....
Are there "other" accessories I should consider,,I would have room for 2 additional items,,,,???
Thx, Doug
Re: What do you have on your "Switch Panel" for your race car ??
[Re: 69CHARGERMD]
#2098235
06/26/16 12:53 AM
06/26/16 12:53 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I run the same stuff as you Doc.. but ran my single center light(in the back window.. the stock light) on a switch... but that filled my panel up EDIT your only required to have a single light in back for night racing... you can see it in the center of the back window at the bottom..... sorry its 90* off
[Re: 69CHARGERMD]
#2098273
06/26/16 02:11 AM
06/26/16 02:11 AM
Posts: 13,201 aZLiViN
J_BODY
aZLiViN
The Duster I now have has a Painless switch panel and relay/fuse bank that rivals a small Cessna..... I hate it, and WILL get things changed or at least straightened out if I choose to have an "off season". Stuff I have: waterpump, fan, electric gauges (want them switched separately so I don't have to have the ign switch on), racepak and O2 sensor (been advised to wire that up separate due to the amp draw... basically switch it on in the lanes to heat it up), trans brake, line lock, shift timer, fuel pump. A lot of the accessories can share a switch, but there are some I want separate. I also have the tach into the same switch as the t brake circuit... that lets me know that it's powered up for sure. I'll sit down and map all the stuff out one day....
[Re: 69CHARGERMD]
#2098452
06/26/16 12:45 PM
06/26/16 12:45 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
I use the second fuel pump circuit for the trans. brake. You don't have to hold the button on the wheel to back up. Saved me once when the button on the wheel didn't hold. I also power the Mega450 off of an accessory switch. Switching it off and back on will act as an override, though I've never used it for that. Yet?
[Re: 69CHARGERMD]
#2098515
06/26/16 02:32 PM
06/26/16 02:32 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Auto Rod Controls 3100 panel is all I use for a conventional car. If one fuel pump is used, - which most do these days - I use the 2nd pump switch for any accessories I want to control independent of the ignition switch. Any thing that might need to be turned on or off during a run (throttle stop override, false brake lights ) is switched separately on a mount at the shifter or someplace easily at hand.
