1970 Service Manual Headlight Warning Buzzer Diode #2097389
06/24/16 02:55 PM
06/24/16 02:55 PM
Washington State
70_FY1_N96_BEEP Offline OP
Washington State
Howdy,
I'm trying to find the correct diode orientation for my Road Runner. Service manual for Valiant, 'Cuda, and Fury show same orientation current flowing from yellow to red. Belvedere schematic shows current flowing red to yellow. Jules had a thread on E body diode a while back which matched service manual orientation. Thanks Moparts, miss Jules a ton....
Re: 1970 Service Manual Headlight Warning Buzzer Diode [Re: 70_FY1_N96_BEEP] #2097659
06/25/16 12:07 AM
06/25/16 12:07 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's an old thread that has some great info and details on the diode..Jules thread is linked to it... 1970 dash wiring PS: The 3 amp diode discussed in that thread{from 08} is still working great...
Re: 1970 Service Manual Headlight Warning Buzzer Diode [Re: 70_FY1_N96_BEEP] #2098039
06/25/16 06:31 PM
06/25/16 06:31 PM
cataclysm80 Offline
cataclysm80  Offline
I also miss Jules a ton.
Tav
Re: 1970 Service Manual Headlight Warning Buzzer Diode [Re: screamindriver] #2098069
06/25/16 07:20 PM
06/25/16 07:20 PM
Washington State
Washington State
Screamindriver, that will do it! Works fine as it should. Great link by the way. GP53.
Re: 1970 Service Manual Headlight Warning Buzzer Diode [Re: screamindriver] #2099157
06/27/16 11:15 AM
06/27/16 11:15 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
If you need the diode itself, it is a 1N4004 1Amp diode. The white band on the diode is the bar end of the schematic diode. They seldom go bad but they do get lost.
Craig
