Griffin Radiators- any feedback?
#2097071
06/24/16 12:13 AM
06/24/16 12:13 AM
Posts: 1,141 NH
NHCharger
NH
http://www.ebay.com/itm/Griffin-Radiator-Electric-Fans-Mopar-A-B-E-Body-Auto-Trans-CU-70038-/351760223706?fits=Year%3A1969%7CMake%3ADodge%7CModel%3ACharger%7CSubmodel%3ADaytona%7CEngine+-+Liter_Display%3A7.2L&hash=item51e68b0dda:g:Y1cAAOSwvg9XYZoJ&vxp=mtr
Need to get a new radiator for my Daytona clone. since nothing is original on the car was wondering if a set up like this would keep the car cooler than a stock set up. Any feedback on this unit would be much appreciated.
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: Griffin Radiators- any feedback?
[Re: NHCharger]
#2097121
06/24/16 01:29 AM
06/24/16 01:29 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
http://www.griffinrad.com/load_details5....;key_id=5-70004They make a Direct fit downflow kit. It's about $1,000. The Radiator without fans is part 5-70004. Search the web for prices, I bought the radiator only off Amazon in Aug 2015 for $578.15. Currently they are showing $672.22 from Summit Racing? The suspension is still apart on the car, so I can't say how it will cool. I am using two 13" low profile Spal cooling fans without a shroud. The two fans cover the majority of the radiator, so I will see how they work. The CU-70038 is for a Chrysler 300 and it is 22.5" x 19" The CU-70004 is a 25.5" wide. Griffins' web page: http://www.griffinrad.com/exact_fit.php?tid=2
[Re: NHCharger]
#2097297
06/24/16 12:15 PM
06/24/16 12:15 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
Here's my ideas on radiators..... Two 1" tubes are better than Four 1/2" tubes, especially when you might have an airflow issue through the grill (and a Daytona almost doesn't have a grill), so that's thumbs up for Griffin.
The negative about Griffins in my opinion is a)cost & b)epoxy joining tubes to headers. Tubes that are brazed to the headers instead of epoxied will transfer heat better, that's why I don't like Griffins. However, if you have a small leak at the tube/header junction, you can fix a Griffin with JB Weld if you had too.
Bottom line... I suggest you see if there's a similar kit from another manufacturer with brazed tubes, but honestly, that Griffin kit looks pretty good. You definitely want a fan shroud that covers the whole radiator & an electric fan temperature controller and that price is a good one. Cross-flow radiators (like Griffin) are less prone to overheating when they're a "little bit low" on coolant, but sometimes you have to get creative with radiator hoses since factory Mopars are top/bottom flow radiators.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Pacnorthcuda]
#2097742
06/25/16 03:52 AM
06/25/16 03:52 AM
Posts: 2,592 None
71rm23
None
who started the rumour that Griffin Radiator tubes are held together with epoxy? they are good quality for the money. Who? Well, Griffin themselves,cause they are. Not saying good or bad (I think pros and cons), but facts are facts, not myths. http://www.griffinrad.com/epoxy_faq.cfm X2
[Re: NHCharger]
#2097839
06/25/16 12:34 PM
06/25/16 12:34 PM
Posts: 1,274 Ontario.Canada
can.al
Ontario.Canada
Current website says Griffin rad tubes are vacuum brazed and as before epoxy is added as a secondary safeguard to add strength
[Re: NHCharger]
#2098074
06/25/16 07:27 PM
06/25/16 07:27 PM
Posts: 1,141 NH
NHCharger
NH
Thanks for all the feedback. I measured this morning and I don't have enough room for this unit. I'll have to touch base with Griffin
[Re: NHCharger]
#2099398
06/27/16 04:43 PM
06/27/16 04:43 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Other than being expensive, I have no complaints about my Griffin radiator. Made a huge difference in cooling on the street in my cuda.
