Tool for Hose Clamps/Rings #2096856
06/23/16 04:58 PM
06/23/16 04:58 PM
Tempe, AZ
loco340cuda Offline OP
Tempe, AZ
I'm in the process of redoing the 340 in my 70 Cuda and I thought it would be cool when I replaced all the hoses to go with the original style hose clamp/rings.
Well, never having dealt with these before (I have only used the modern screw type hose clamps) I have quickly come to find out they are a real pain in the a** to try to put on. I have tried using channel lock pliers to try to put these things on and it just is not working.
Is there a special tool that you use to get these things on and off?
Here is a picture of the hose clamp/rings that I am talking about.
-Thanks
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Tool for Hose Clamps/Rings [Re: loco340cuda] #2096859
06/23/16 05:02 PM
06/23/16 05:02 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Re: Tool for Hose Clamps/Rings [Re: loco340cuda] #2096923
06/23/16 07:11 PM
06/23/16 07:11 PM
Zombieland
Car Nut Online laugh2
Zombieland
Napa sells KD corbin hose clamp pliers too.
Re: Tool for Hose Clamps/Rings [Re: loco340cuda] #2096932
06/23/16 07:38 PM
06/23/16 07:38 PM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
Re: Tool for Hose Clamps/Rings [Re: loco340cuda] #2096980
06/23/16 09:48 PM
06/23/16 09:48 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Even with proper Corbin tool, can be a bit challenging on some of the hoses.
On my E Body 440, find on the thermostat housing clamp was better to first place the clamp on the housing, then slip the hose into position, then use the tool to expand the clamp over the hose into its proper position. Some tools will not expand clamp enough to get the clamp over the ridge on the housing.
Be careful at the heater end, as these fittings are prone to break off from heater if you have to wrestle too hard to get the hose on and the clamp in position. A shot of dishwashing soap or Wd 40 can help in sliding a brand new hose into position.
Be certain to position them such that you do not end up slicing your forearm or wrist while working on the engine. These pointy edges can be quite sharp and to catch your wrist is something you won't soon forget. I have not yet had the pleasure but every time I look at these clamps keeps me wary.
Re: Tool for Hose Clamps/Rings [Re: Sxrxrnr] #2097000
06/23/16 10:19 PM
06/23/16 10:19 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
I dont know how many knuckles I have busted with the damn things...
But the screw on clamps look like hell....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Tool for Hose Clamps/Rings [Re: Car Nut] #2097007
06/23/16 10:39 PM
06/23/16 10:39 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
X2 on the KD's. They work well. Two different V cuts that swivel and a good locking mechanism.
Re: Tool for Hose Clamps/Rings [Re: JMCFAN] #2097008
06/23/16 10:39 PM
06/23/16 10:39 PM
You might take a pair of regular pliers & file 2 opposite grooves in the serrated flats at the end. Might save you time/money rather than the corbins
Re: Tool for Hose Clamps/Rings [Re: RapidRobert] #2097021
06/23/16 11:11 PM
06/23/16 11:11 PM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
So the channel locks and pliers I use are the wrong tool? rolleyes
Re: Tool for Hose Clamps/Rings [Re: Ramrod39] #2097023
06/23/16 11:13 PM
06/23/16 11:13 PM
correct, as they just dont secure the ends enough once you compress em/plus bad angle
Re: Tool for Hose Clamps/Rings [Re: RapidRobert] #2097033
06/23/16 11:21 PM
06/23/16 11:21 PM
Tucson, AZ
My New Title
My New Title
Tucson, AZ
Been getting by without them for decades...
Re: Tool for Hose Clamps/Rings [Re: Ramrod39] #2097059
06/23/16 11:57 PM
06/23/16 11:57 PM
Been getting by with them for decades...
me too for one or two of em but if I had to do the (14) in the pic I would mod some pliers or get the corbin
Re: Tool for Hose Clamps/Rings [Re: RapidRobert] #2097072
06/24/16 12:13 AM
06/24/16 12:13 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Post deleted
Re: Tool for Hose Clamps/Rings [Re: loco340cuda] #2097078
06/24/16 12:24 AM
06/24/16 12:24 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have the KD tool, have had it for a long long time, carry it in my truck tool pouch for the fuel filter replacement. Tips swivel to all positions which makes tight areas easy.
Re: Tool for Hose Clamps/Rings [Re: RapidRobert] #2097167
06/24/16 02:33 AM
06/24/16 02:33 AM
Tucson, AZ
My New Title
My New Title
Tucson, AZ
Yeah, if was using those clamps, having the proper tool would make sense. Fact is though, I usually take those clamps off and replace them with worm gear clamps. I just like them better...
Re: Tool for Hose Clamps/Rings [Re: Ramrod39] #2097168
06/24/16 02:39 AM
06/24/16 02:39 AM
agreed as worm clamps are so common that I am used to em (be sure to get quality ones/no cheapies). I've heard way back that corbins are good cuz they keep a constant tension but I'm sure the worm clamps do to
Re: Tool for Hose Clamps/Rings [Re: loco340cuda] #2097173
06/24/16 02:51 AM
06/24/16 02:51 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Yeah.. my worm gear clamps when they leak are always at the worm gear. corbin clamps have a better seal, but are a PITA.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Tool for Hose Clamps/Rings [Re: DARTH V8Я] #2097320
06/24/16 12:58 PM
06/24/16 12:58 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
The weak point on worm gears.. You can find better screw type clamps at hydraulic shops that work well....
Re: Tool for Hose Clamps/Rings [Re: minivan] #2097329
06/24/16 01:15 PM
06/24/16 01:15 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
As pointed out above (in the SK flavor) there are the correct pliers:
http://www.ebay.com/itm/Snap-On-Tools-Hose-Clamp-Slip-Joint-Pliers-HCP48BP-/191901374951
The others are universal and almost dangerous for this type of application (good way to get hurt IMO).
Also, you might look into getting clamps that are one size smaller than what comes in the resto kits. I had trouble with this style of clamp leaking due to the newer style hoses being a bit thinner than the originals. The main problem was at the heater hose connections.
Re: Tool for Hose Clamps/Rings [Re: loco340cuda] #2097537
06/24/16 07:10 PM
06/24/16 07:10 PM
Downey, CA.
BB14404SPD Offline
BB14404SPD  Offline
Downey, CA.
