Tool for Hose Clamps/Rings
#2096856
06/23/16 04:58 PM
06/23/16 04:58 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I'm in the process of redoing the 340 in my 70 Cuda and I thought it would be cool when I replaced all the hoses to go with the original style hose clamp/rings.
Well, never having dealt with these before (I have only used the modern screw type hose clamps) I have quickly come to find out they are a real pain in the a** to try to put on. I have tried using channel lock pliers to try to put these things on and it just is not working.
Is there a special tool that you use to get these things on and off?
Here is a picture of the hose clamp/rings that I am talking about.
-Thanks
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
Re: Tool for Hose Clamps/Rings
[Re: loco340cuda]
#2096859
06/23/16 05:02 PM
06/23/16 05:02 PM
Posts: 7,368 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: Sxrxrnr]
#2097000
06/23/16 10:19 PM
06/23/16 10:19 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
I dont know how many knuckles I have busted with the damn things...
But the screw on clamps look like hell....
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: Car Nut]
#2097007
06/23/16 10:39 PM
06/23/16 10:39 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Napa sells KD corbin hose clamp pliers too. X2 on the KD's. They work well. Two different V cuts that swivel and a good locking mechanism.
[Re: JMCFAN]
#2097008
06/23/16 10:39 PM
06/23/16 10:39 PM
RapidRobert
You might take a pair of regular pliers & file 2 opposite grooves in the serrated flats at the end. Might save you time/money rather than the corbins
[Re: Ramrod39]
#2097023
06/23/16 11:13 PM
06/23/16 11:13 PM
RapidRobert
correct, as they just dont secure the ends enough once you compress em/plus bad angle
[Re: RapidRobert]
#2097033
06/23/16 11:21 PM
06/23/16 11:21 PM
Posts: 9,122 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
correct, as they just dont secure the ends enough once you compress em/plus bad angle Been getting by without them for decades...
[Re: Ramrod39]
#2097059
06/23/16 11:57 PM
06/23/16 11:57 PM
RapidRobert
correct, as they just dont secure the ends enough once you compress em/plus bad angle Been getting by with them for decades... me too for one or two of em but if I had to do the (14) in the pic I would mod some pliers or get the corbin
[Re: RapidRobert]
#2097072
06/24/16 12:13 AM
06/24/16 12:13 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: loco340cuda]
#2097078
06/24/16 12:24 AM
06/24/16 12:24 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have the KD tool, have had it for a long long time, carry it in my truck tool pouch for the fuel filter replacement. Tips swivel to all positions which makes tight areas easy.
[Re: RapidRobert]
#2097167
06/24/16 02:33 AM
06/24/16 02:33 AM
Ramrod39
My New Title
My New Title
Tucson, AZ
correct, as they just dont secure the ends enough once you compress em/plus bad angle Been getting by with them for decades... me too for one or two of em but if I had to do the (14) in the pic I would mod some pliers or get the corbin Yeah, if was using those clamps, having the proper tool would make sense. Fact is though, I usually take those clamps off and replace them with worm gear clamps. I just like them better...
[Re: Ramrod39]
#2097168
06/24/16 02:39 AM
06/24/16 02:39 AM
RapidRobert
agreed as worm clamps are so common that I am used to em (be sure to get quality ones/no cheapies). I've heard way back that corbins are good cuz they keep a constant tension but I'm sure the worm clamps do to
[Re: loco340cuda]
#2097173
06/24/16 02:51 AM
06/24/16 02:51 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Yeah.. my worm gear clamps when they leak are always at the worm gear. corbin clamps have a better seal, but are a PITA.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DARTH V8Я]
#2097320
06/24/16 12:58 PM
06/24/16 12:58 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Yeah.. my worm gear clamps when they leak are always at the worm gear. corbin clamps have a better seal, but are a PITA. The weak point on worm gears.. You can find better screw type clamps at hydraulic shops that work well....
[Re: minivan]
#2097329
06/24/16 01:15 PM
06/24/16 01:15 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
As pointed out above (in the SK flavor) there are the correct pliers: http://www.ebay.com/itm/Snap-On-Tools-Hose-Clamp-Slip-Joint-Pliers-HCP48BP-/191901374951The others are universal and almost dangerous for this type of application (good way to get hurt IMO). Also, you might look into getting clamps that are one size smaller than what comes in the resto kits. I had trouble with this style of clamp leaking due to the newer style hoses being a bit thinner than the originals. The main problem was at the heater hose connections.
[Re: RapidRobert]
#2097542
06/24/16 07:35 PM
06/24/16 07:35 PM
Posts: 1,295 New Jersey
Powerflow
New Jersey
You might take a pair of regular pliers & file 2 opposite grooves in the serrated flats at the end. Might save you time/money rather than the corbins I've got a factory-made tool like that. Don't know the manufacturer. There are no serrations in the jaws, just grooves to hold the clamp.
[Re: Powerflow]
#2097601
06/24/16 09:52 PM
06/24/16 09:52 PM
loco340cuda
Tempe, AZ
Thanks everyone. I went to NAPA and bought their tool. It is nice and says Made in USA. What I like about it is that it locks so once you press the straight ends of the hose clamp together with the tool it locks in place and will hold it until you release the tension with a lever on the tool.
[Re: minivan]
#2097615
06/24/16 10:23 PM
06/24/16 10:23 PM
RapidRobert
The weak point on worm gears.. You can find better screw type clamps at hydraulic shops that work well.... Noted! I need some better ones for the braided steel fuel lines as I need the extra clamping for the barbed fittings as they ain't really the correct ones for this app
[Re: Ramrod39]
#2098059
06/25/16 07:00 PM
06/25/16 07:00 PM
Ramrod39
My New Title
My New Title
Tucson, AZ
correct, as they just dont secure the ends enough once you compress em/plus bad angle Been getting by without them for decades... It's a funny world out there. The morning after posting this I stopped at a yard sale. What was waiting for me there? Yep, a proper set of locking hose clamp pliers. Old, but of good quality and in good condition. They are in my toolbox now and I'm $2 lighter in the wallet. I figure they came to me because I posted that I did not need them. I don't need to win the lottery...
