Question on ring gap with boost #2096291
06/22/16 03:57 PM
06/22/16 03:57 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
My little motor has .018 ring gap on top and second rings.
Under 6-8 pounds of blower boost, is pushing the gaps together an issue. Should ring gaps be set wider under such circumstances?
I don't want to pull the motor apart.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Question on ring gap with boost [Re: B3422W5] #2096555
06/23/16 12:56 AM
06/23/16 12:56 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
What's the top ring at? This is a 3.94" bore?
Re: Question on ring gap with boost [Re: B3422W5] #2096579
06/23/16 01:39 AM
06/23/16 01:39 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I set mine at .020 top and second with a 4.065 bore and was told that could handle a 150 shot fine. On a smaller bore .018 might be fine at 8 lbs.
Mopar to the bone!!!
Re: Question on ring gap with boost [Re: B3422W5] #2096638
06/23/16 09:03 AM
06/23/16 09:03 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Top ring gapped at .018. 3. 94 bore
1.41 best 60 foot
6.56 at 104.17
Re: Question on ring gap with boost [Re: B3422W5] #2096678
06/23/16 11:31 AM
06/23/16 11:31 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
The boost pressure is not the concern, it is the extra heat a turbo generates. Much like a nitrous application, the top gap should be a little wider than for N/A application.
Re: Question on ring gap with boost [Re: TheOtherDodge] #2096684
06/23/16 11:43 AM
06/23/16 11:43 AM
Az
Crizila Offline
Crizila  Offline
Az
Yep, gotta run them wider for the heat issue. Usually 4-5 thou over NA motor.
Fastest 300
Re: Question on ring gap with boost [Re: B3422W5] #2096691
06/23/16 11:52 AM
06/23/16 11:52 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
It's for a blower setup, not a turbo, regards my question
Torqstorm blower setup, produces 8 pounds boost max
1.41 best 60 foot
6.56 at 104.17
Re: Question on ring gap with boost [Re: B3422W5] #2096700
06/23/16 12:11 PM
06/23/16 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Don.. if you put a inner cooler it would help in multiple ways..
it would keep the temps down and make more power.. as said...
heat is what hurts the rings(butting)..plus try to keep the
coolant temp down... its all heat
wave
Re: Question on ring gap with boost [Re: B3422W5] #2096703
06/23/16 12:15 PM
06/23/16 12:15 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
You will be fine
Re: Question on ring gap with boost [Re: B3422W5] #2096715
06/23/16 12:34 PM
06/23/16 12:34 PM
Houston, Texas
Houston, Texas
Even with a blower there is heat, but not as much.
At only 8 lbs of boost, you don't need anything special as FastmOp states. Mr. P also makes a good statement but you really don't need an intercooler at those low levels, but everything sure does help. Plus, you will eventually up the boost...
Re: Question on ring gap with boost [Re: B3422W5] #2097103
06/24/16 12:58 AM
06/24/16 12:58 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
That setup only makes 8 pounds of boost. It's a nice governor on my wallet. More power, more money, less wife likes the idea.
Figure it's enough to dip well into the 10's.
1.41 best 60 foot
6.56 at 104.17
Re: Question on ring gap with boost [Re: B3422W5] #2097170
06/24/16 02:39 AM
06/24/16 02:39 AM
The more,longer you drive the car the more the intake manifold inlet temps go up, more heat is not good work
As far as end gap no way would I think of using that close of a top gap next time on your deal, make it .022+ and don't worry anymore. I would set the second gap between .024 to .030 also up
Once the ring gaps butt together,especailly at W.O.T., it will cause more problems than you want to have shruggy
