Question on ring gap with boost
#2096291
06/22/16 03:57 PM
06/22/16 03:57 PM
Posts: 11,716 Portage,michigan
B3422W5
Portage,michigan
My little motor has .018 ring gap on top and second rings. Under 6-8 pounds of blower boost, is pushing the gaps together an issue. Should ring gaps be set wider under such circumstances? I don't want to pull the motor apart.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Question on ring gap with boost
[Re: B3422W5]
#2096579
06/23/16 01:39 AM
06/23/16 01:39 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I set mine at .020 top and second with a 4.065 bore and was told that could handle a 150 shot fine. On a smaller bore .018 might be fine at 8 lbs.
Mopar to the bone!!!
[Re: B3422W5]
#2096638
06/23/16 09:03 AM
06/23/16 09:03 AM
B3422W5
Portage,michigan
Top ring gapped at .018. 3. 94 bore
[Re: TheOtherDodge]
#2096684
06/23/16 11:43 AM
06/23/16 11:43 AM
Posts: 7,506 Az
Crizila
Az
The boost pressure is not the concern, it is the extra heat a turbo generates. Much like a nitrous application, the top gap should be a little wider than for N/A application. Yep, gotta run them wider for the heat issue. Usually 4-5 thou over NA motor.
Fastest 300
[Re: B3422W5]
#2096691
06/23/16 11:52 AM
06/23/16 11:52 AM
B3422W5
Portage,michigan
It's for a blower setup, not a turbo, regards my question Torqstorm blower setup, produces 8 pounds boost max
[Re: B3422W5]
#2096700
06/23/16 12:11 PM
06/23/16 12:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It's for a blower setup, not a turbo, regards my question Torqstorm blower setup, produces 8 pounds boost max Don.. if you put a inner cooler it would help in multiple ways.. it would keep the temps down and make more power.. as said... heat is what hurts the rings(butting)..plus try to keep the coolant temp down... its all heat
[Re: B3422W5]
#2097103
06/24/16 12:58 AM
06/24/16 12:58 AM
B3422W5
Portage,michigan
That setup only makes 8 pounds of boost. It's a nice governor on my wallet. More power, more money, less wife likes the idea. Figure it's enough to dip well into the 10's.
[Re: B3422W5]
#2097170
06/24/16 02:39 AM
06/24/16 02:39 AM
Posts: 43,213 Bend,OR USA
Cab_Burge
The more,longer you drive the car the more the intake manifold inlet temps go up, more heat is not good As far as end gap no way would I think of using that close of a top gap next time on your deal, make it .022+ and don't worry anymore. I would set the second gap between .024 to .030 also Once the ring gaps butt together,especailly at W.O.T., it will cause more problems than you want to have
