Rear Diff brake line
#2094503
06/19/16 04:18 PM
06/19/16 04:18 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
70 RR. Ordered set for 70... but rear diff is wrong... to late to return. Do I need to order 69?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Rear Diff brake line
[Re: NANKET]
#2094520
06/19/16 04:59 PM
06/19/16 04:59 PM
JMCFAN
New Mexico
Inline Tube.. 30 days ... I swear...never used...oh well...rest of the set is fine
[Re: NANKET]
#2094522
06/19/16 05:00 PM
06/19/16 05:00 PM
JMCFAN
New Mexico
The brass t is bolted on backwards but that won't help the lines. Which vendor did you buy from? Yea its loose... but line is too long anyway..
[Re: JMCFAN]
#2094546
06/19/16 06:07 PM
06/19/16 06:07 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
'70 and later had the vent located further to the left so your housing isn't a '70. You need lines for a '65-'69 B-body.
[Re: John_Kunkel]
#2094547
06/19/16 06:09 PM
06/19/16 06:09 PM
JMCFAN
New Mexico
Thanks!
[Re: John_Kunkel]
#2094732
06/20/16 12:42 AM
06/20/16 12:42 AM
Posts: 959 Chicago
PurpleBeeper
Chicago
Yep, ran into this exact same issue with my '70 Roadrunner 8-3/4" rear end. '70 is a change-over year between the two locations for the brass "splitter" which are about 2" or so different & you could have either one on a '70. The company where I got my brake lines (maybe Inline?) just sent me the "other set" of rear brake lines no charge. Maybe the guys you bought yours from will do that? If not, take some measurements & I will see if my "extra set" of rear brake lines happen to be the ones you need (stainless fyi). And now that I look at your picture a little bit closer, I see that you can easily cut & re-flare the passenger line you have shown in the picture. The problem will be that your driver side line is too short.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: fastmark]
#2094854
06/20/16 10:21 AM
06/20/16 10:21 AM
Posts: 2,592 None
71rm23
None
If you would have bought your brake lines from Cass ( DoctorDiff) on the board here, he would have asked you to measure your housing to see which lines you needed. Yes this is a shameless plug! Agree
[Re: JMCFAN]
#2094894
06/20/16 11:57 AM
06/20/16 11:57 AM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
Well your axle is already done and your problem is both lines are going to be wrong. you need to confirm the body connection is in the same place 665-69 vs. 70 , if it is then you need to order a 69 rubber line also , it would need to be longer to reach the same place .
Now when I ran into this problem instead on panic I just drilled and tapped the hole in the correct location and red loctited the appropriate size set screw in the other hole. But since the rear is already together and looks like ready to install that not an easy option ...
[Re: fastmark]
#2094970
06/20/16 02:13 PM
06/20/16 02:13 PM
JMCFAN
New Mexico
If you would have bought your brake lines from Cass ( DoctorDiff) on the board here, he would have asked you to measure your housing to see which lines you needed. Yes this is a shameless plug! Have a email in to DrDiff.. he is on vacation... will wait till he returns.
[Re: JMCFAN]
#2094982
06/20/16 02:31 PM
06/20/16 02:31 PM
John_Kunkel
Rio Linda, CA
Here's the vent location info Cass provided:
Vent hole locations
'67-'69 A-body housing: Vent bolt location: 7.75" from center of housing
'70-'72 A-body housing: Vent bolt location: 11.25" from center of housing
'65-'67 B-body housing: Vent bolt location: 7.75" from center of housing
'68-'69 B-body housing; Vent bolt location: 7.75" from center of housing
'70 B-body housing: Vent bolt location: 11.25" from center of housing
'71-'72 B-body housing (not station wagon): Vent bolt location: 11.25" from center of housing
'73-'74 B-body housing (not station wagon): Vent bolt location: 11.25" from center of housing
'70-'74 E-body housing: Vent bolt location: 11.25" from center of housing
'65-'69 C-body housing: Vent bolt location: 7.75" from center of housing
[Re: Morty426]
#2096389
06/22/16 08:06 PM
06/22/16 08:06 PM
JohnRR
U.S.S.A.
Is this relocation 8 3/4 rear ends only? Good question , I have both 68 and 70 B body Dana 60s so I can look at them.
