Rear Diff brake line #2094503
06/19/16 04:18 PM
06/19/16 04:18 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
70 RR. Ordered set for 70... but rear diff is wrong... to late to return. Do I need to order 69?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Rear Diff brake line [Re: JMCFAN] #2094517
06/19/16 04:48 PM
06/19/16 04:48 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The brass t is bolted on backwards but that won't help the lines. Which vendor did you buy from?
Re: Rear Diff brake line [Re: NANKET] #2094520
06/19/16 04:59 PM
06/19/16 04:59 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Inline Tube.. 30 days ... I swear...never used...oh well...rest of the set is fine
Re: Rear Diff brake line [Re: NANKET] #2094522
06/19/16 05:00 PM
06/19/16 05:00 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Yea its loose... but line is too long anyway..
Re: Rear Diff brake line [Re: JMCFAN] #2094546
06/19/16 06:07 PM
06/19/16 06:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'70 and later had the vent located further to the left so your housing isn't a '70. You need lines for a '65-'69 B-body.
Re: Rear Diff brake line [Re: John_Kunkel] #2094547
06/19/16 06:09 PM
06/19/16 06:09 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks!
Re: Rear Diff brake line [Re: JMCFAN] #2094652
06/19/16 10:48 PM
06/19/16 10:48 PM
BlueRacer69 Offline
BlueRacer69  Offline
In the past I've always used FineLines, for all my lines without any issues so far. Of course in your case it wouldn't of mattered anyway.
Re: Rear Diff brake line [Re: John_Kunkel] #2094732
06/20/16 12:42 AM
06/20/16 12:42 AM
Chicago
PurpleBeeper Offline
Chicago
Yep, ran into this exact same issue with my '70 Roadrunner 8-3/4" rear end. '70 is a change-over year between the two locations for the brass "splitter" which are about 2" or so different & you could have either one on a '70.
The company where I got my brake lines (maybe Inline?) just sent me the "other set" of rear brake lines no charge. Maybe the guys you bought yours from will do that? If not, take some measurements & I will see if my "extra set" of rear brake lines happen to be the ones you need (stainless fyi).
And now that I look at your picture a little bit closer, I see that you can easily cut & re-flare the passenger line you have shown in the picture. The problem will be that your driver side line is too short.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Rear Diff brake line [Re: JMCFAN] #2094837
06/20/16 09:25 AM
06/20/16 09:25 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
If you would have bought your brake lines from Cass ( DoctorDiff) on the board here, he would have asked you to measure your housing to see which lines you needed. Yes this is a shameless plug!
Re: Rear Diff brake line [Re: fastmark] #2094854
06/20/16 10:21 AM
06/20/16 10:21 AM
None
71rm23 Offline
71rm23  Offline
None
Agree
Re: Rear Diff brake line [Re: JMCFAN] #2094894
06/20/16 11:57 AM
06/20/16 11:57 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Well your axle is already done and your problem is both lines are going to be wrong. you need to confirm the body connection is in the same place 665-69 vs. 70 , if it is then you need to order a 69 rubber line also , it would need to be longer to reach the same place .
Now when I ran into this problem instead on panic I just drilled and tapped the hole in the correct location and red loctited the appropriate size set screw in the other hole. But since the rear is already together and looks like ready to install that not an easy option ...
Re: Rear Diff brake line [Re: JMCFAN] #2094912
06/20/16 12:15 PM
06/20/16 12:15 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Is this relocation 8 3/4 rear ends only?
Re: Rear Diff brake line [Re: Morty426] #2094913
06/20/16 12:18 PM
06/20/16 12:18 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Same with A-Body 8-3/4 rear ends. 69 down is one set of lines, 70-72 is another for the same reason. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: Rear Diff brake line [Re: fastmark] #2094970
06/20/16 02:13 PM
06/20/16 02:13 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Have a email in to DrDiff.. he is on vacation... will wait till he returns.
Re: Rear Diff brake line [Re: JMCFAN] #2094982
06/20/16 02:31 PM
06/20/16 02:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's the vent location info Cass provided:
Vent hole locations
'67-'69 A-body housing: Vent bolt location: 7.75" from center of housing
'70-'72 A-body housing: Vent bolt location: 11.25" from center of housing
'65-'67 B-body housing: Vent bolt location: 7.75" from center of housing
'68-'69 B-body housing; Vent bolt location: 7.75" from center of housing
'70 B-body housing: Vent bolt location: 11.25" from center of housing
'71-'72 B-body housing (not station wagon): Vent bolt location: 11.25" from center of housing
'73-'74 B-body housing (not station wagon): Vent bolt location: 11.25" from center of housing
'70-'74 E-body housing: Vent bolt location: 11.25" from center of housing
'65-'69 C-body housing: Vent bolt location: 7.75" from center of housing
Re: Rear Diff brake line [Re: John_Kunkel] #2095251
06/20/16 09:54 PM
06/20/16 09:54 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Wow! Thanks!
Re: Rear Diff brake line [Re: Morty426] #2096389
06/22/16 08:06 PM
06/22/16 08:06 PM
JohnRR Offline
JohnRR  Offline
Good question , I have both 68 and 70 B body Dana 60s so I can look at them.
