Wheel hop / Driveline angel? #2096089
06/22/16 09:36 AM
06/22/16 09:36 AM
Norway
cudaerik Offline OP
cudaerik  Offline OP
Norway
I'm struggling with severe wheel hop om my 1970 Plymouth Cuda.
The car is a street car that is set up with a 500 cubic inch low deck stroker, TKO 600 5 speed manual transmission, split monoleafs (new bushings) caltracks bars, brand new Bilstein shocks and BFG TA street radials.
Current driveline angels: transmission yoke 4 degrees down, driveshaft 2 degrees down, pinion yoke 3 degrees down.
I do not have the chance to raise the rear of the transmission more due to clearance issues in the transmission tunnel. What angel do the transmission yoke have on a stock 4 speed car?
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Wheel hop / Driveline angel? [Re: cudaerik] #2096102
06/22/16 10:17 AM
06/22/16 10:17 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your driveline/pinion angles look good IMHO, have you considered the tires?...on my Charger when I run BFG's wheel hop like mad when I dump the clutch, when running Goodyears no issues, like two different cars
Re: Wheel hop / Driveline angel? [Re: cudaerik] #2096151
06/22/16 11:20 AM
06/22/16 11:20 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
That sure is a beautiful car. You have a 7 degree difference between the downward angle of the pinion angle and the angle of the centerline of your engine/trans. That is way too much with Caltracs. If memory serves, it should be closer to 2 degrees.
Call Calvert and follow their advice on adjusting your pinion angle and their bars. Your car should not wheel hop with properly set-up Caltracs regardless of tires.
That thing must be squirelly with those POS Radial TA's. Try a set of Nitto drag radials if you want to hook up a lot better on the street. I love mine.
Re: Wheel hop / Driveline angel? [Re: cudaerik] #2096243
06/22/16 02:44 PM
06/22/16 02:44 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Tires can make a huge difference. When I drive on TA tires it is like being in a rain storm, zero traction. Other street radials are way better at holding the pavement. The BFG Ta is near a low end garbage tire IMO.
