Head/Port size for us #2092758
06/15/16 11:54 PM
06/15/16 11:54 PM
Australia
O
ozymaxwedge Offline OP
O
Australia
Hey guys,
My sons engine is just a short as he has always used my heads but it is time he got his own.
Engine is 440 30 over TRWs, about 11.5-1, cam is 266 @ 50, 603 lift solid mechanical, external oil feed. shift kitted manual 727, new 5000 stall. Car is for fun/street/drag.
My heads that have been on it (before the 5000 conv)are Indy SR's that have been maxed out and flow 370cfm, his exaust system will not allow an exhaust port in a lower position.
We are thinking of goin another set of SR's but should we stay with standard port size with this combo ?
Do the new Trick flows have raised exhaust port ?
1963 Plymouth Max Wedge
1971 Barracuda
Re: Head/Port size for us [Re: ozymaxwedge] #2092776
06/16/16 12:27 AM
06/16/16 12:27 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Trickflows are standard port location , they are a performance replacement of stock head .
Didn't you have some trickflows for this ?
Maybe wait a little for the trickflow maxwedge supposed to be coming soon ?
You have a little more comp and cam than my 440 with cnc stealths , mine 10.78ish , 258@050 - 520 net lift
bigger heads will let you grow - when you go stroker . LOL up
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Head/Port size for us [Re: ozymaxwedge] #2092786
06/16/16 12:43 AM
06/16/16 12:43 AM
Australia
O
O
Australia
Tex, the trick flows I posted was on a friends 440 build.
As I said in another thread we have a 547 in the young blokes VG Valiant but it aint staying there LOL. I think some here will say stay with a smaller port for his combo but maybe with the 5000 stall the big port will be OK ??. It should be an easy 10.50 car.
1971 Barracuda
Re: Head/Port size for us [Re: ozymaxwedge] #2092842
06/16/16 03:31 AM
06/16/16 03:31 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Al , I have a 5000 stall with my standard port heads goes 10's . I fitted max wedge Sidewinder heads from Todd@Moparts/Marsh Performance on a mates 440ci motor . it has 10:1 , 4400ish vert , 4.1 gears and a 1050 dommy . I did put a little smaller cam 251/259 Lunati . Drives great on the street , I think it went 385/390RWHP . This was within 1000klm after rebuild and through 4 mufflers , so there is more to come hopefully
You could call Todd , prices were good on the Sidewinders . And he was great to deal with . I don't think they needed offset rockers either , I was only replacing the max wedge Eddys and did not have to replace rockers
Stock exhaust port location , had Hooker Comps on it
Tex
New best MPH 130.32
Re: Head/Port size for us [Re: ozymaxwedge] #2095939
06/21/16 11:33 PM
06/21/16 11:33 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Al
Maybe custom headers like these. Low deck in a VE
Tex
New best MPH 130.32
Re: Head/Port size for us [Re: ozymaxwedge] #2095962
06/22/16 12:12 AM
06/22/16 12:12 AM
Australia
O
O
Australia
We will stay with the Headman Fenderwell exit pipes Tex,much more space, he has already made the full 3.5" system and done a great job.
1971 Barracuda
Re: Head/Port size for us [Re: tex013] #2096025
06/22/16 02:04 AM
06/22/16 02:04 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By tex013
Al
Tex
Very nice n clean....... thumbs
Re: Head/Port size for us [Re: ozymaxwedge] #2096032
06/22/16 02:22 AM
06/22/16 02:22 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I would go with another set of SR heads. Pushrod lenght should stay the same saving a couple bucks.
Re: Head/Port size for us [Re: ozymaxwedge] #2096034
06/22/16 02:28 AM
06/22/16 02:28 AM
gregsdart Offline
gregsdart  Offline
Larger port heads will most likely tempt you to run it at higher rpm because it will make power higher up, and I got nervous when I saw the heavy pistons mentioned. For my twocents I would go with standard port heads and keep the revs down to make it live a long happy life.
Re: Head/Port size for us [Re: ozymaxwedge] #2096054
06/22/16 04:33 AM
06/22/16 04:33 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
your not wrong . these are Victor max wedge heads .
just trying to help up
Tex
New best MPH 130.32
