Head/Port size for us
#2092758
06/15/16 11:54 PM
06/15/16 11:54 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Hey guys,
My sons engine is just a short as he has always used my heads but it is time he got his own. Engine is 440 30 over TRWs, about 11.5-1, cam is 266 @ 50, 603 lift solid mechanical, external oil feed. shift kitted manual 727, new 5000 stall. Car is for fun/street/drag. My heads that have been on it (before the 5000 conv)are Indy SR's that have been maxed out and flow 370cfm, his exaust system will not allow an exhaust port in a lower position.
We are thinking of goin another set of SR's but should we stay with standard port size with this combo ? Do the new Trick flows have raised exhaust port ?
1963 Plymouth Max Wedge 1971 Barracuda
Re: Head/Port size for us
[Re: ozymaxwedge]
#2092776
06/16/16 12:27 AM
06/16/16 12:27 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Trickflows are standard port location , they are a performance replacement of stock head . Didn't you have some trickflows for this ? Maybe wait a little for the trickflow maxwedge supposed to be coming soon ? You have a little more comp and cam than my 440 with cnc stealths , mine 10.78ish , 258@050 - 520 net lift bigger heads will let you grow - when you go stroker . LOL Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: ozymaxwedge]
#2092786
06/16/16 12:43 AM
06/16/16 12:43 AM
ozymaxwedge
Australia
Tex, the trick flows I posted was on a friends 440 build.
As I said in another thread we have a 547 in the young blokes VG Valiant but it aint staying there LOL. I think some here will say stay with a smaller port for his combo but maybe with the 5000 stall the big port will be OK ??. It should be an easy 10.50 car.
[Re: ozymaxwedge]
#2092842
06/16/16 03:31 AM
06/16/16 03:31 AM
tex013
Sydney,Australia
Al , I have a 5000 stall with my standard port heads goes 10's . I fitted max wedge Sidewinder heads from Todd@Moparts/Marsh Performance on a mates 440ci motor . it has 10:1 , 4400ish vert , 4.1 gears and a 1050 dommy . I did put a little smaller cam 251/259 Lunati . Drives great on the street , I think it went 385/390RWHP . This was within 1000klm after rebuild and through 4 mufflers , so there is more to come hopefully You could call Todd , prices were good on the Sidewinders . And he was great to deal with . I don't think they needed offset rockers either , I was only replacing the max wedge Eddys and did not have to replace rockers Stock exhaust port location , had Hooker Comps on it
Tex
[Re: ozymaxwedge]
#2095939
06/21/16 11:33 PM
06/21/16 11:33 PM
tex013
Sydney,Australia
Al Maybe custom headers like these. Low deck in a VE
Tex
[Re: tex013]
#2096025
06/22/16 02:04 AM
06/22/16 02:04 AM
Thumperdart
State of confusion
Tex Very nice n clean.......
[Re: ozymaxwedge]
#2096032
06/22/16 02:22 AM
06/22/16 02:22 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I would go with another set of SR heads. Pushrod lenght should stay the same saving a couple bucks.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: ozymaxwedge]
#2096034
06/22/16 02:28 AM
06/22/16 02:28 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Larger port heads will most likely tempt you to run it at higher rpm because it will make power higher up, and I got nervous when I saw the heavy pistons mentioned. For my I would go with standard port heads and keep the revs down to make it live a long happy life.
[Re: ozymaxwedge]
#2096054
06/22/16 04:33 AM
06/22/16 04:33 AM
tex013
Sydney,Australia
We will stay with the Headman Fenderwell exit pipes Tex,much more space, he has already made the full 3.5" system and done a great job. your not wrong . these are Victor max wedge heads . just trying to help Tex
