489 carrier housing #2094011
06/18/16 04:37 PM
06/18/16 04:37 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
Can you tell by looking at the outside of a 489 carrier housing (minus the posi tag)if it is a posi or not?
Re: 489 carrier housing [Re: johnfin] #2094018
06/18/16 04:50 PM
06/18/16 04:50 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It MAY have an orange paint daub on the drain plug IF it came with a Sure Grip & IF it has not had the daub added or the guts changed.
Check it, that is the only way to know for sure.
Re: 489 carrier housing [Re: johnfin] #2094104
06/18/16 07:55 PM
06/18/16 07:55 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
With the jacked up....both wheels turn the same direction when wheels are turned...when driveshaft is turned same thing....so a position for sure..right?
Re: 489 carrier housing [Re: johnfin] #2094133
06/18/16 09:20 PM
06/18/16 09:20 PM
Kirkland, Washington
Pacnorthcuda Offline
Yes its a sure grip. Positraction is Chevy's name for a limited slip. Sure Grip is Mopar's name.
Re: 489 carrier housing [Re: Pacnorthcuda] #2094237
06/19/16 12:42 AM
06/19/16 12:42 AM
I'd jack either rear wheel off the ground & bear hug it & crank it forward & see how difficult it is to break it loose (trans in neutral)
Re: 489 carrier housing [Re: johnfin] #2094310
06/19/16 09:46 AM
06/19/16 09:46 AM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
Do a burnout, only true test I am aware of.
_______no good
==========good to go
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
Re: 489 carrier housing [Re: PlumCrazy73Dodge] #2094429
06/19/16 02:07 PM
06/19/16 02:07 PM
_______no good
One possible outcome of that test is not knowing if you have an open or a burned up sure grip.
Re: 489 carrier housing [Re: johnfin] #2094512
06/19/16 04:37 PM
06/19/16 04:37 PM
Jack the rear end up off the ground and put it on jackstands then try and turn one wheel in park if it won't turn it probally is a posi center, if the other wheel turns opostite of the direction your turning your wheel it is a non posi center section scope IHTHs thumbs If you put in any other gear but park and spin a rear tire and the other tire spins the opposite way, if the other tire spins the same way your turning and the driveshaft matches the tire rotation you have a posi thumbs
Re: 489 carrier housing [Re: Pacnorthcuda] #2094549
06/19/16 06:19 PM
06/19/16 06:19 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
_______no good
Yep. Even if it's an open differential it's possible to lay down two identical patches.
Burnouts prove nothing about nothing.
Re: 489 carrier housing [Re: johnfin] #2094881
06/20/16 11:36 AM
06/20/16 11:36 AM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
In a sure grip, if one wheel is on the ground and one wheel is jacked up, driveshaft disconnected, can you turn the tire by hand or will the clutches be too strong to release?
Re: 489 carrier housing [Re: johnfin] #2094885
06/20/16 11:44 AM
06/20/16 11:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If the clutches are not burned up, or the cones bottomed out and offering no resistance, you will not be able to turn the tire on not on the ground without considerable effort.
Re: 489 carrier housing [Re: John_Kunkel] #2094888
06/20/16 11:46 AM
06/20/16 11:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
_______no good
Exactly, I've done it many times with an open rear
Re: 489 carrier housing [Re: johnfin] #2094975
06/20/16 02:18 PM
06/20/16 02:18 PM
with a good forward bearhug you'll get it to let loose
Re: 489 carrier housing [Re: johnfin] #2094978
06/20/16 02:23 PM
06/20/16 02:23 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
I had a peg leg lock up, gears jammed and it was full posi. both turned and did double blacks on the pavement. It was broken.
Re: 489 carrier housing [Re: johnfin] #2095014
06/20/16 02:58 PM
06/20/16 02:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's something that happens to a pegleg after many ... and I mean MANY .... one wheel burnouts of insane speed and length. I took a one legger apart once where I had to use a hammer to assist the spider crosspin out because the spiders were galled on the shaft...
Re: 489 carrier housing [Re: RapidRobert] #2095017
06/20/16 03:00 PM
06/20/16 03:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You must be ... \russian accent ... "STRONG LIKE BULL" ... or it's was a POS cone type that was almost toast ... wink
Re: 489 carrier housing [Re: johnfin] #2095031
06/20/16 03:28 PM
06/20/16 03:28 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
The break away torque cant be too much or the car would skid around corners. Wonder what that torque is.
Re: 489 carrier housing [Re: JohnRR] #2095302
06/20/16 11:10 PM
06/20/16 11:10 PM
I ain't sure double R, it was 30 yrs ago & it broke loose with a medium amt of effort & rotated forward several inches iirc. & I was thinking it was a clutch one. EDIT Johnfin I vaguely remember a torque spec of 150 lbs for em (should take (at least) that or more to move it)
Re: 489 carrier housing [Re: johnfin] #2095433
06/21/16 02:23 AM
06/21/16 02:23 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi, sure-grip cone clutch might slip... sure-grip clutch plate tight... sure-grip cone clutch machine and shimmed... very tight... ronnie
