Re: 489 carrier housing
[Re: johnfin]
#2094133
06/18/16 09:20 PM
06/18/16 09:20 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
With the jacked up....both wheels turn the same direction when wheels are turned...when driveshaft is turned same thing....so a position for sure..right? Yes its a sure grip. Positraction is Chevy's name for a limited slip. Sure Grip is Mopar's name.
[Re: Pacnorthcuda]
#2094237
06/19/16 12:42 AM
06/19/16 12:42 AM
RapidRobert
I'd jack either rear wheel off the ground & bear hug it & crank it forward & see how difficult it is to break it loose (trans in neutral)
[Re: johnfin]
#2094310
06/19/16 09:46 AM
06/19/16 09:46 AM
Posts: 2,112 New Jersey, US of A
PlumCrazy73Dodge
New Jersey, US of A
Do a burnout, only true test I am aware of. _______no good
==========good to go
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
[Re: PlumCrazy73Dodge]
#2094429
06/19/16 02:07 PM
06/19/16 02:07 PM
Pacnorthcuda
==========good to go One possible outcome of that test is not knowing if you have an open or a burned up sure grip.
[Re: johnfin]
#2094512
06/19/16 04:37 PM
06/19/16 04:37 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
Jack the rear end up off the ground and put it on jackstands then try and turn one wheel in park if it won't turn it probally is a posi center, if the other wheel turns opostite of the direction your turning your wheel it is a non posi center section IHTHs If you put in any other gear but park and spin a rear tire and the other tire spins the opposite way, if the other tire spins the same way your turning and the driveshaft matches the tire rotation you have a posi
[Re: Pacnorthcuda]
#2094549
06/19/16 06:19 PM
06/19/16 06:19 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
==========good to go One possible outcome of that test is not knowing if you have an open or a burned up sure grip. Yep. Even if it's an open differential it's possible to lay down two identical patches. Burnouts prove nothing about nothing.
[Re: johnfin]
#2094885
06/20/16 11:44 AM
06/20/16 11:44 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
In a sure grip, if one wheel is on the ground and one wheel is jacked up, driveshaft disconnected, can you turn the tire by hand or will the clutches be too strong to release? If the clutches are not burned up, or the cones bottomed out and offering no resistance, you will not be able to turn the tire on not on the ground without considerable effort.
[Re: John_Kunkel]
#2094888
06/20/16 11:46 AM
06/20/16 11:46 AM
JohnRR
U.S.S.A.
==========good to go One possible outcome of that test is not knowing if you have an open or a burned up sure grip. Yep. Even if it's an open differential it's possible to lay down two identical patches. Burnouts prove nothing about nothing. Exactly, I've done it many times with an open rear
[Re: johnfin]
#2094975
06/20/16 02:18 PM
06/20/16 02:18 PM
RapidRobert
In a sure grip, if one wheel is on the ground and one wheel is jacked up, driveshaft disconnected, can you turn the tire by hand or will the clutches be too strong to release? with a good forward bearhug you'll get it to let loose
[Re: johnfin]
#2095014
06/20/16 02:58 PM
06/20/16 02:58 PM
JohnRR
U.S.S.A.
I had a peg leg lock up, gears jammed and it was full posi. both turned and did double blacks on the pavement. It was broken. That's something that happens to a pegleg after many ... and I mean MANY .... one wheel burnouts of insane speed and length. I took a one legger apart once where I had to use a hammer to assist the spider crosspin out because the spiders were galled on the shaft...
[Re: RapidRobert]
#2095017
06/20/16 03:00 PM
06/20/16 03:00 PM
JohnRR
U.S.S.A.
In a sure grip, if one wheel is on the ground and one wheel is jacked up, driveshaft disconnected, can you turn the tire by hand or will the clutches be too strong to release? with a good forward bearhug you'll get it to let loose You must be ... \russian accent ... "STRONG LIKE BULL" ... or it's was a POS cone type that was almost toast ...
[Re: JohnRR]
#2095302
06/20/16 11:10 PM
06/20/16 11:10 PM
RapidRobert
In a sure grip, if one wheel is on the ground and one wheel is jacked up, driveshaft disconnected, can you turn the tire by hand or will the clutches be too strong to release? with a good forward bearhug you'll get it to let loose You must be ... \russian accent ... "STRONG LIKE BULL" ... or it's was a POS cone type that was almost toast ... I ain't sure double R, it was 30 yrs ago & it broke loose with a medium amt of effort & rotated forward several inches iirc. & I was thinking it was a clutch one. EDIT Johnfin I vaguely remember a torque spec of 150 lbs for em (should take (at least) that or more to move it)
