Re: 1st Test hit with 1150 Thumper Carb Video
[Re: DemonDust]
#2094527
06/19/16 05:15 PM
06/19/16 05:15 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Spun the rubber bands like 4-5 times. Otherwise car sounds mean man. Couldn't hear anything wrong carb-wise.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: DemonDust]
#2094729
06/20/16 12:36 AM
06/20/16 12:36 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Did it lay down a bit early before picking up in 1st or was that you off and on the peddle a little ? Sounds fantastic.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: DemonDust]
#2094735
06/20/16 12:46 AM
06/20/16 12:46 AM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Are you talking about the beginning where you load up the converter before you launch? Way beyond my paygrade but it sounded like it was trying to lay down a little there unless you stepped off it for another reason. Kevin
[Re: ozymaxwedge]
#2094737
06/20/16 12:47 AM
06/20/16 12:47 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Did it lay down a bit early before picking up in 1st or was that you off and on the peddle a little ? Sounds fantastic. Nailed it^^^^^^ That was all the car. I didn't get out of the throttle.
[Re: DemonDust]
#2094776
06/20/16 01:57 AM
06/20/16 01:57 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Like when we talked, make sure the acc. pump cams are adjusted properly after setting the idle and play w/the squirters first going up in size and try again but 02 info really helps a lot and shortens the "tuning"time........
[Re: DemonDust]
#2094807
06/20/16 03:27 AM
06/20/16 03:27 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Is that laydown also about when the secondaries are opening?
Mopar to the bone!!!
[Re: tsanchez]
#2094986
06/20/16 02:40 PM
06/20/16 02:40 PM
Thumperdart
State of confusion
Agreed and could be carb or not and apparently it did this w/the 4150 so,......Float levels and squirters to start and of course your w/b hooked up for feedback.......
[Re: DemonDust]
#2095114
06/20/16 05:29 PM
06/20/16 05:29 PM
Posts: 216 America
WedgeFED
America
Sounds like it was having problems in second gear also? Nice sounds good...Like the testing grounds also
[Re: WedgeFED]
#2095146
06/20/16 06:31 PM
06/20/16 06:31 PM
Thumperdart
State of confusion
I think he said it was spinning in second.......
[Re: DemonDust]
#2095274
06/20/16 10:29 PM
06/20/16 10:29 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Seems like the rpm leveled out and would not pull past that point,,,,,,
[Re: hemi-itis]
#2095308
06/20/16 11:18 PM
06/20/16 11:18 PM
Thumperdart
State of confusion
I think that "point" was near 9000`rs........
