1st Test hit with 1150 Thumper Carb Video #2094513
06/19/16 04:41 PM
06/19/16 04:41 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I'm not gonna say anything, let me know what issues you see if any. 275 ET pros.
R5P7 test hit
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094527
06/19/16 05:15 PM
06/19/16 05:15 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Spun the rubber bands like 4-5 times. Otherwise car sounds mean man. Couldn't hear anything wrong carb-wise.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094664
06/19/16 11:09 PM
06/19/16 11:09 PM
Menomonee Falls
Menomonee Falls
192 views..... Maybe I'm being too anal.
Either way I'm going to fix the problem I see.
Yes, in 2nd gear it rolled the tires a few times before it had a good hook.
SDG Motorsports
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094683
06/19/16 11:28 PM
06/19/16 11:28 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I didn't watch it to nit pick your new combo. It sounded good to me!
What rpm did you take it to?
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094712
06/20/16 12:19 AM
06/20/16 12:19 AM
Menomonee Falls
Menomonee Falls
I had the shift light set to 9200.
There's a little hiccup that bothers me I was just hoping someone else would notice. And maybe have some advice on what it is. I currently have no data to show anything that's going on besides the video.
I'm going to call racepak tomorrow and get something that will work for me.
SDG Motorsports
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094729
06/20/16 12:36 AM
06/20/16 12:36 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Did it lay down a bit early before picking up in 1st or was that you off and on the peddle a little ? Sounds fantastic.
1963 Plymouth Max Wedge
1971 Barracuda
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094735
06/20/16 12:46 AM
06/20/16 12:46 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Are you talking about the beginning where you load up the converter before you launch?
Way beyond my paygrade but it sounded like it was trying to lay down a little there unless you stepped off it for another reason. shruggy
Kevin
Re: 1st Test hit with 1150 Thumper Carb Video [Re: ozymaxwedge] #2094737
06/20/16 12:47 AM
06/20/16 12:47 AM
Menomonee Falls
Menomonee Falls
Nailed it^^^^^^
That was all the car. I didn't get out of the throttle.
SDG Motorsports
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094746
06/20/16 12:56 AM
06/20/16 12:56 AM
Menomonee Falls
Menomonee Falls
It hits 6k drops to 5k for a split second then tachs up. Not sure if convertor issue or carb issue. But I'm sure a racepak will tell all, or almost all.
SDG Motorsports
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094759
06/20/16 01:22 AM
06/20/16 01:22 AM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Watched it about 10 more times. Thought at first it just spun then dug in hence the rpm drop, but it could have been the secondary jets getting uncovered. shruggy
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094776
06/20/16 01:57 AM
06/20/16 01:57 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Like when we talked, make sure the acc. pump cams are adjusted properly after setting the idle and play w/the squirters first going up in size and try again but 02 info really helps a lot and shortens the "tuning"time........
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094807
06/20/16 03:27 AM
06/20/16 03:27 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Is that laydown also about when the secondaries are opening?
Mopar to the bone!!!
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094863
06/20/16 10:52 AM
06/20/16 10:52 AM
Menomonee Falls
Menomonee Falls
They should be open at that point, since I put the pedal to floor instantly.
SDG Motorsports
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2094934
06/20/16 01:01 PM
06/20/16 01:01 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Almost seems like thats where the converter grabs, it flashes past then finally grabs hold and pulls the engine down a touch. Or its splashing fuel from the vent
Re: 1st Test hit with 1150 Thumper Carb Video [Re: tsanchez] #2094986
06/20/16 02:40 PM
06/20/16 02:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed and could be carb or not and apparently it did this w/the 4150 so,......Float levels and squirters to start and of course your w/b hooked up for feedback.......
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2095114
06/20/16 05:29 PM
06/20/16 05:29 PM
America
WedgeFED Offline
WedgeFED  Offline
America
Sounds like it was having problems in second gear also? Nice sounds good...Like the testing grounds also
Re: 1st Test hit with 1150 Thumper Carb Video [Re: WedgeFED] #2095146
06/20/16 06:31 PM
06/20/16 06:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I think he said it was spinning in second.......
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2095212
06/20/16 08:18 PM
06/20/16 08:18 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Man that thing sounds awesome !!!!
Re: 1st Test hit with 1150 Thumper Carb Video [Re: DemonDust] #2095274
06/20/16 10:29 PM
06/20/16 10:29 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Seems like the rpm leveled out and would not pull past that point,,,,,,
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 1st Test hit with 1150 Thumper Carb Video [Re: hemi-itis] #2095308
06/20/16 11:18 PM
06/20/16 11:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I think that "point" was near 9000`rs........
