rocker arms and vavle covers #209412
01/31/09 03:48 PM
01/31/09 03:48 PM
PA, USA
moparpilot1 Offline OP
PA, USA
anybody know if the old isky adj. ductile rocker arms will fit under stock big block vavle covers with about .550 lift thanks
Re: rocker arms and vavle covers [Re: moparpilot1] #209413
01/31/09 04:54 PM
01/31/09 04:54 PM
Indiana
MFR426 Offline
MFR426  Offline
Indiana
We used to use them and the only problem we had was the adjuster hit the baffles in a couple of spots. A tap with a punch on the baffle gave us enough clearance with no problems. Use a thick gasket as well for a little more height. The new Moroso silicone type would work good I would think. Good Luck!
MFR426
Re: rocker arms and vavle covers [Re: MFR426] #209414
01/31/09 11:02 PM
01/31/09 11:02 PM
MFR426
I had one customer that use a small hole saw to remove the dented part of the baffle instead of dimpling it with a punch
Re: rocker arms and vavle covers [Re: Cab_Burge] #209415
02/01/09 01:38 AM
02/01/09 01:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We have the Crane ductile iron rockers under these stock valve covers. It has the MP .557 cam and they do not hit. Ron
