What PN is assembly line correct for 1970 383HP distributor #2094081
06/18/16 07:08 PM
06/18/16 07:08 PM
St. Paul, MN
stat5 Offline OP
stat5  Offline OP
St. Paul, MN
What part number is assembly line correct for a 383HP distributor. Is it 3438233 or 3438433 because the dealer parts book lists both?
If it matters this is an e-body with a SPD of 829 and car was built in the Hamtramck plant.
Also were distributors built in batches because when I look at the distributor repo tags offered by Bill Rolik he only offers 4 different date codes? Was it possible to have other date codes then the 4 offered by Rolik?
Thanks for all answers
Re: What PN is assembly line correct for 1970 383HP distributor [Re: stat5] #2094288
06/19/16 03:21 AM
06/19/16 03:21 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Galen's "white book" ONLY lists the 3438233 for all 383 4bbl engines - all transmissions & B, C, E-bodies
I'd ASSUME that there were more than 4 weeks of 383 4bbl distributor production.
Re: What PN is assembly line correct for 1970 383HP distributor [Re: stat5] #2094925
06/20/16 12:44 PM
06/20/16 12:44 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
3438233 would be the assembly line part and 3438234 would be the replacement.
I think Bill makes tags based on known production dates and spread out as to cover the year. It wouldn't be economical for that application to make a tag for every day of the year.
If you have your original he might be able to reproduce it
Re: What PN is assembly line correct for 1970 383HP distributor [Re: Morty426] #2094943
06/20/16 01:15 PM
06/20/16 01:15 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
But a tag for that early of a production date would have the word CHRYSLER on it, which Bill is NOT allowed to stamp on the tag. The original tag is a slightly metallic green color. I have a few early original ones if you are interested.
Re: What PN is assembly line correct for 1970 383HP distributor [Re: m46rat] #2095276
06/20/16 10:30 PM
06/20/16 10:30 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I did not know what Bill is able and not able to do but you are correct.
Re: What PN is assembly line correct for 1970 383HP distributor [Re: Morty426] #2095590
06/21/16 12:21 PM
06/21/16 12:21 PM
m46rat Offline
m46rat  Offline
He would need permission or have to pay some kind of licensing fee to Chrysler if he planned on using that word. All of his reproduction tags are ones without CHRYSLER on the tag.
Re: What PN is assembly line correct for 1970 383HP distributor [Re: m46rat] #3025397
03/19/22 11:36 AM
03/19/22 11:36 AM
Kingston, IL USA!
gts340swinger Offline
Kingston, IL USA!
I know someone who has an original green tag 3438233 distributor with a 41. 9 date code. It does not say Chrysler on the tag. I can ask him how much he wants if you are interested.
Mr. Norm's "Fanatic" (idiot)
71 Mr. Norm's Demon GSS
77 Mr. Norm's personal B250 GSS van
76 Mr. Norm's KZ900 Motor Sports Special
69 Mr. Norm's M code Dart GTS
69 D100
68 Barracuda
64 Valiant V200
07 Charger Daytona SST 6 speed test mule.
