440-1C #2093111
06/16/16 06:30 PM
06/16/16 06:30 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Just wondering if there is anything out there now that compares to this head. Must be iron.
Re: 440-1C [Re: mac56] #2093160
06/16/16 08:13 PM
06/16/16 08:13 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
It's the iron version of the 440-1....and it's HEAVY iron.
I had a chance to buy a dirt cheap NIB set, but after picking one of them up, i opted out.
Re: 440-1C [Re: mac56] #2093172
06/16/16 08:47 PM
06/16/16 08:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Not that I know of...... And afaik, the 440-1C's haven't been available for a couple of years.
Re: 440-1C [Re: fast68plymouth] #2093383
06/17/16 09:25 AM
06/17/16 09:25 AM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Your kidding. I called there yesterday to price a new set. They gave me a price but she didnt know how much for 2.25 intake option. Told me to call back today. Ours are cracked between valve seats.
Re: 440-1C [Re: mac56] #2093387
06/17/16 09:31 AM
06/17/16 09:31 AM
gregsdart Offline
gregsdart  Offline
I bet you can find a used set. They are so heavy, I am sure others who bought them then upgraded to aluminum later. DAMHIK.
if you do find a set, and need 2.25 intake valves, let me know. I will let go of the seven valves I have for half of retail. Very low use, maybe 250 runs, one valve job on them.
Re: 440-1C [Re: gregsdart] #2093447
06/17/16 12:01 PM
06/17/16 12:01 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Yeah not sure about used ones. These dont have much time on them and cracked.
Re: 440-1C [Re: mac56] #2093458
06/17/16 12:26 PM
06/17/16 12:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
They have a reputation for cracking, unfortunately.
Re: 440-1C [Re: mac56] #2093465
06/17/16 12:38 PM
06/17/16 12:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have had a set since 98
Re: 440-1C [Re: mac56] #2093471
06/17/16 12:51 PM
06/17/16 12:51 PM
So. Burlington, Vt.
So. Burlington, Vt.
I tried getting a couple of sets about two years ago for some tractor pulling guys.
There were none to be had, and at the time, Russ told me they were having a hard time finding a foundry that was willing to do a small run of them(like 20 heads).
Apparently, they are not fast movers for Indy.
As far as the cracks go, have them pressure tested. If they don't leak, just keep running them.
In some of the oval track classes, Dart iron SBC heads crack between the seats very often. The guys just keep running them........ No problems.
