Re: World Aluminum HEMI block
[Re: fuseable]
#2093257
06/16/16 11:58 PM
06/16/16 11:58 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
No real problems with mine. I changed out the generic main studs for real ARP. Also had to order correct head gaskets, as they are different. I got the correct part no. from Rich Nedball for Cometic gaskets. My engine is fairly mild, not set on kill. I purchased the parts years ago, so may not be the same as the currently available block. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: fuseable]
#2093446
06/17/16 12:00 PM
06/17/16 12:00 PM
Hemi Allstate
Mt. Eden Ky.
No Eric, It has been over a year. Life happens. I closed my business and moved, built a new building at home last year, to work in. I switched to a Holley Dominator, from the 4150 Demon carb, and I don't have it sorted out yet. Only 1 pass on the Holley. 6.02 @ 115.7 with a 1.33 60 ft. The car runs 5.98 & 5.99 115. and change pretty consistently with the Demon carb. I hope to do better this year. The car is ready, but it is getting hot & humid now! LOL I feel that there is more HP in this combination, than what I am getting out of it. We will see! Thanks, Mark
[Re: fuseable]
#2094150
06/18/16 10:05 PM
06/18/16 10:05 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Well hopefully that makes them cheaper, then I can afford the headache...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: moderncylinder]
#2094392
06/19/16 01:04 PM
06/19/16 01:04 PM
Posts: 1,237 North Central, Indiana
Roughbird72
The New Blocks have an issue
Oil hole from the mains to lifter oil galley is not drilled threw BLIND HOLE
Your mains will never see oil Pour mineral spirits or a fluid of your choice down the hole to be sure yours has been corrected If its together and hasent fired yet take it apart
its about 3/16 to 1/4 short of hitting the feed hole
you can drill it by hand with a long drill
This is not isolated to a few this is ALL NEW BLOCKS Available today Quality Control must have had the week off
72 Plymouth Roadrunner 11.08@123.25
#2098132
06/25/16 09:28 PM
06/25/16 09:28 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I have also had blocks where the oil feeds to the heads from the oil galleys were drilled, and tapped for the restrictor, but the restrictors didn't have the holes. Well, at least they installed a "plug" so you didn't over oil the top end - LOL.
