wanting a air fuel mixture gauge any suggestions
#2088664
06/08/16 10:46 PM
06/08/16 10:46 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
like the fast cause it does both banks ,not the price , both my chargers have big blocks with headers !!! street cars . auto meter has a bunch of gauges , anyone using one ? OR am I opening up pandoras box !! ones ben on the road for 9 years other is almost ready after 7 years in the building .
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: wanting a air fuel mixture gauge any suggestions
[Re: sparcy]
#2088667
06/08/16 10:52 PM
06/08/16 10:52 PM
RapidRobert
am I opening up pandoras box !! not at all! I have an innovate LM1 but I ain't hooked it up yet (bought it used from a CL character so hopefully it is still OK). I have the 8MM bung needing to be welded in. iirc there are some round gauge ones that you can permanently mount in the dash that are pretty accurate. I'm looking forward to the responses also
[Re: sparcy]
#2088724
06/08/16 11:50 PM
06/08/16 11:50 PM
sparcy
dracut mass usa
welding is no problem , have mig and tig in my shop !! thinking fathers day present wife wants to get me some tin i can really use , LOL told her i think i got a idea
[Re: sparcy]
#2088836
06/09/16 01:44 AM
06/09/16 01:44 AM
Posts: 5,163 CT
GTX MATT
CT
Lots of people use the Innovate gauges and they're supposed to be a good. I use the AEM UEGO, it was cheaper when I bought mine and it has a really good reputation in the tuner community. Whatever you do just make sure its a wideband and has an actual digital readout...
[Re: GTX MATT]
#2088895
06/09/16 09:41 AM
06/09/16 09:41 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
I use an Innovate LC1, my brother uses the AEM one, both work ok.
The only Carbs I care about are under the hood!
[Re: sparcy]
#2088941
06/09/16 11:33 AM
06/09/16 11:33 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Depends on what you are going to do with it. I am moving to EFI this summer so I wanted one that had an output I could use for engine management. I went with the Innovate MTX. In the year I have had it on the car logging and helping with tuning, it has been great. I have been able to chart the changes in gasoline formulations, carburetor adjustments, etc. Now I have a baseline to reasonably judge the EFI changes and what they mean. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: sparcy]
#2092762
06/16/16 12:04 AM
06/16/16 12:04 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I run two of the FAST analog gauges mounted together so that I can reference the readings as I drive. I do not have any needs to record the data, I just reference them at a glance while I am driving. They are both 5+ years old and I have had no issues with them. (except a recent loose ground wire that was my fault.)
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
