wanting a air fuel mixture gauge any suggestions #2088664
06/08/16 10:46 PM
06/08/16 10:46 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
like the fast cause it does both banks ,not the price , both my chargers have big blocks with headers !!! street cars . auto meter has a bunch of gauges , anyone using one ? OR am I opening up pandoras box !! ones ben on the road for 9 years other is almost ready after 7 years in the building .
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2088667
06/08/16 10:52 PM
06/08/16 10:52 PM
not at all! I have an innovate LM1 but I ain't hooked it up yet (bought it used from a CL character so hopefully it is still OK). I have the 8MM bung needing to be welded in. iirc there are some round gauge ones that you can permanently mount in the dash that are pretty accurate. I'm looking forward to the responses also
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2088724
06/08/16 11:50 PM
06/08/16 11:50 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
welding is no problem , have mig and tig in my shop !! thinking fathers day present wife wants to get me some tin i can really use , LOL told her i think i got a idea
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2088836
06/09/16 01:44 AM
06/09/16 01:44 AM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Lots of people use the Innovate gauges and they're supposed to be a good. I use the AEM UEGO, it was cheaper when I bought mine and it has a really good reputation in the tuner community. Whatever you do just make sure its a wideband and has an actual digital readout...
Re: wanting a air fuel mixture gauge any suggestions [Re: GTX MATT] #2088895
06/09/16 09:41 AM
06/09/16 09:41 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I use an Innovate LC1, my brother uses the AEM one, both work ok.
The only Carbs I care about are under the hood!
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2088941
06/09/16 11:33 AM
06/09/16 11:33 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Depends on what you are going to do with it. I am moving to EFI this summer so I wanted one that had an output I could use for engine management. I went with the Innovate MTX. In the year I have had it on the car logging and helping with tuning, it has been great. I have been able to chart the changes in gasoline formulations, carburetor adjustments, etc. Now I have a baseline to reasonably judge the EFI changes and what they mean.
Craig
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2089678
06/10/16 03:26 PM
06/10/16 03:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'm using an innovate LC-1 with an in-dash gauge. It's relatively cheap compared to the LM-1, however the LC-1 does not datalog if that's important to you.
Is there any reason you want to run two sensors? Are you jetting one side of the carb different from the next or running a cross ram intake of some kind?
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2089681
06/10/16 03:40 PM
06/10/16 03:40 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I bought a LM1 from Innovate before they came out with the LM2. Used it about 4 times and it took a dump. Innovate wants too much money to diagnose it and fix it. I heard the AEM UEGO is really good.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2089728
06/10/16 05:24 PM
06/10/16 05:24 PM
central il.
second 70 Offline
second 70  Offline
central il.
Innovate MTX no problems in 3 + years
Re: wanting a air fuel mixture gauge any suggestions [Re: second 70] #2089729
06/10/16 05:28 PM
06/10/16 05:28 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Same here smile
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2092762
06/16/16 12:04 AM
06/16/16 12:04 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I run two of the FAST analog gauges mounted together so that I can reference the readings as I drive. I do not have any needs to record the data, I just reference them at a glance while I am driving. They are both 5+ years old and I have had no issues with them. (except a recent loose ground wire that was my fault.)
Re: wanting a air fuel mixture gauge any suggestions [Re: sparcy] #2095239
06/20/16 09:33 PM
06/20/16 09:33 PM
CA
bbodee Offline
bbodee  Offline
CA
I installed a summit UEGO in my build. It's exactly the AEM unit rebranded with a different faceplate.
I've only had it in and used it for cam break in and 4 different 10-15 minute test drives, but it seems to be working correctly and very responsive to show changes as it relates to tuning. (So far set idle mixture, checked off-idle AFR, cruise AFR)
Price is right too, less than $200
