Re: 426 Hemi dampner hits oil pan?
[Re: Rhinodart]
#2092030
06/14/16 08:56 PM
06/14/16 08:56 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
is the lower timing gear on the crank ?
[Re: CSK]
#2092044
06/14/16 09:27 PM
06/14/16 09:27 PM
Posts: 43,609 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
No. There is no cam in it so I did not install the timing gears. So the are you saying the dampner will rest against the timing gear?
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2092045
06/14/16 09:29 PM
06/14/16 09:29 PM
Posts: 4,457 Washington
madscientist
Washington
No. There is no cam in it so I did not install the timing gears. So the are you saying the dampner will rest against the timing gear? Yes, that was what he was saying. You need the gear on. The damper butts up against the crank gear.
[Re: Rhinodart]
#2092047
06/14/16 09:30 PM
06/14/16 09:30 PM
RapidRobert
Hello Jimmy. Is the timing cover on?
[Re: RapidRobert]
#2092063
06/14/16 09:58 PM
06/14/16 09:58 PM
Rhinodart
Rhinotruck
Rhinotruck
Yes the timing cover is on and so is the water pump housing. I never thought about what stops the dampner from bottoming out on the crank, now I know! Guess I got to get the dampner puller out, take off the water pump housing and timing cover, and put the gear on...
A-Body's RULE!
[Re: Rhinodart]
#2092066
06/14/16 10:07 PM
06/14/16 10:07 PM
Rhinodart
Rhinotruck
Rhinotruck
What is the diameter and height of the correct single groove crank pulley for a super stock Hemi?
A-Body's RULE!
[Re: Rhinodart]
#2092158
06/15/16 12:03 AM
06/15/16 12:03 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Hey, Hey , stop pulling our legs. Someone with over 31,000 post doesn't know that the timing gear has to go on ? come on. And why is the timing cover and water pump on? painting ?
[Re: rowin4]
#2092194
06/15/16 01:01 AM
06/15/16 01:01 AM
Posts: 4,952 northwest USA
NANKET
northwest USA
Hey, Hey , stop pulling our legs. Someone with over 31,000 post doesn't know that the timing gear has to go on ? come on. And why is the timing cover and water pump on? painting ? Does the number of moparts posts make or break a person as a great mechanic.
[Re: Rhinodart]
#2092215
06/15/16 01:57 AM
06/15/16 01:57 AM
RapidRobert
Jimmy You're doing fine. when the time comes I may have a pulley for you
[Re: Cab_Burge]
#2092344
06/15/16 11:30 AM
06/15/16 11:30 AM
Rhinodart
Rhinotruck
Rhinotruck
I have the thick balancer.
A-Body's RULE!
[Re: Rhinodart]
#2092387
06/15/16 12:43 PM
06/15/16 12:43 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
The stock 68/69-71 Hemi crank pulley is shorter than a stock B/RB pulley by about .75". Put your water pump pulley on and pull the dampner out till the V belt grooves line up ,,, this is just mock up , no need to tear it all down to put the crank gear/oil slinger in place Jim there are 2 hemi lower pulleys, it all depends on what water pump pulley you use. Up until ... I think .... sometime in 68 the Hemi used the standard B/RB waterpump pulley and had a very shallow crank pulley ... again "I think" ... that pulley is what the Milodon alum crank pulley is based off ? Then sometime in 68 Chrysler changed to the shallower Hemi only water pump pulley and the crank pulley was made a little deeper.
