Porting iron P-car heads & whoops! #2091458
06/13/16 10:44 PM
06/13/16 10:44 PM
Its a TRAP!
DARTH V8Я Offline OP
Oh No!! I just had a moron attack!
Its a TRAP!
Got about 30 hours on the intakes went to do the exhaust, and then I seen em.. AIR PUMP PORTS. rolleyes
So can they be epoxied? Or do I have to braze em shut? Also, just the outside ones, or the inside ones? Thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2091463
06/13/16 10:55 PM
06/13/16 10:55 PM
USA
B3RE Offline
B3RE  Offline
USA
Drill and tap the holes for a set screw that will sit below the flange surface. It's been a while since I did a set, but you might not have to drill if the hole size is right for tapping. Can't remember if it was 1/4" or 5/16".
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2091473
06/13/16 11:05 PM
06/13/16 11:05 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
The holes will take a 5/16th coarse tap. Thread them and put 5/16th set screws in them. I just did a set yesterday on the 360 going in my truck.
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2091506
06/14/16 12:25 AM
06/14/16 12:25 AM
Its a TRAP!
Its a TRAP!
Thanks gentlemen thumbs
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2091800
06/14/16 02:38 PM
06/14/16 02:38 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have been doing the same to the heads that I have. I tapped 7 of them successfully using my 5/16 - 18 thread tap and then broke the tap in the hole on #8 whiney
I have now broken it off below the surface (it keeps crumbling) and resists easy removal. My next step is to use my Dremel and a tiny grinder bit to get all the rest of it out. I will use a proper pre drill bit and go up to a 3/8 - 16 tap on one hole in this head. Just a little hiccup in the process. I know better, I just wanted to hurry the process and it bit me in the A** mad
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Porting iron P-car heads & whoops! [Re: Polarapete] #2091825
06/14/16 03:21 PM
06/14/16 03:21 PM
dogdays Offline
dogdays  Offline
I too broke off a tap in my 302 heads. The AIR holes in my heads were about exactly 1/4". I found a 5/16" tap and found the proper drill bit, then drilled the first inch or a little more. Tapped to 5/16 - 18. I had a bunch of 1" Grade 2 bolts so I ran-em in as far as I could and cut off the heads. Messy but OK. I used a small punch to work on the broken off tap, then filled the hole, with the remainder of the tap still inside, with JB Weld. There's been no sign of leakage from any of the holes. I believe when the exhaust gases can't travel through, the holes carbon up pretty quickly.
I believe if you drilled out the holes so they were clean that JB Weld would be all you needed. In my case I had too many bolts.
R.
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2091905
06/14/16 05:00 PM
06/14/16 05:00 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
30hrs grinding intake ports on OE iron heads??? Yikes!!!
Noooooo thanks......
Re: Porting iron P-car heads & whoops! [Re: Polarapete] #2091915
06/14/16 05:14 PM
06/14/16 05:14 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Just heat the broken tap with a cutting torch and and give it a quick shot of oxygen. The broken tap will instantly vanish.
Kevin
Re: Porting iron P-car heads & whoops! [Re: fast68plymouth] #2091920
06/14/16 05:19 PM
06/14/16 05:19 PM
Its a TRAP!
Its a TRAP!
Cause I don't have your skills smile Good thing I don't charge myself labor laugh2
#1 of 8 lol. So like this? What about the hole inside the port? Leave it?
Re: Porting iron P-car heads & whoops! [Re: Twostick] #2091924
06/14/16 05:23 PM
06/14/16 05:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Kevin
Heat to what color? Heard this before on removing broken studs and things.
Re: Porting iron P-car heads & whoops! [Re: Twostick] #2091948
06/14/16 06:02 PM
06/14/16 06:02 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Kevin
I would do that if they were just cores and no great loss, but the heads had been through a machine shop, valves ground, PC stem seals on all valves etc. (the full treatment) are completely assembled and I don't want to heat the one and risk any further steps back. I will just get comfortable with the Dremel and work it out.
2008 Honda Element
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2091959
06/14/16 06:18 PM
06/14/16 06:18 PM
Washington
madscientist Offline
Washington
I grind the bump down and let it go. Just keep plugging the holes like you are.
Re: Porting iron P-car heads & whoops! [Re: madscientist] #2091966
06/14/16 06:30 PM
06/14/16 06:30 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I still have a few sets of iron heads leaning against the wall in my garage but so far I have been smart enough not to touch them. I hope I stay smart enough for the rest of my life so my kids can scrap them after I'm dead.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Porting iron P-car heads & whoops! [Re: pittsburghracer] #2091983
06/14/16 06:59 PM
06/14/16 06:59 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I just used spare/old bolts. Drill/tapped, bottomed them good, ground them off & flush. Buh-bye to dat. Those ports'll never get smog hdwr on any day.
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2091985
06/14/16 07:04 PM
06/14/16 07:04 PM
P
Porter67 Offline
Porter67  Offline
P
If you break a tap off below the surface, screw getting it out as if you got a torch just fill it with braze, or clean and arc hit it with nickle rod.
Re: Porting iron P-car heads & whoops! [Re: pittsburghracer] #2091995
06/14/16 07:21 PM
06/14/16 07:21 PM
Its a TRAP!
Its a TRAP!
Calling me dumb? mad Seems about right! laugh2
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092073
06/14/16 10:25 PM
06/14/16 10:25 PM
Its a TRAP!
Its a TRAP!
WAIT! I WAS right! Had a stop on the drill bit, and I hit water.. junk in 30 seconds. rolleyes
Well well well well.. what's Summits # again? laugh2
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092090
06/14/16 10:48 PM
06/14/16 10:48 PM
PA.
"Little"John
"Little"John
PA.
You are killing me over here. LOL I'm trying to get ready for a Mopar race weekend.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092097
06/14/16 10:55 PM
06/14/16 10:55 PM
P
Porter67 Offline
Porter67  Offline
P
Why didnt you just tap the existing small holes and use a smaller threaded plug?
The few sets of smoggers ive done I dont recall ever pre drilling, but I did break a cheap tap one time, just butsed it up with a tiny punch and it dumped out.
If you just jacked 30 hours work it might be cheaper to buy some heads, that iron material and dust isnt good for your lungs.
Re: Porting iron P-car heads & whoops! [Re: DARTH V8Я] #2092122
06/14/16 11:20 PM
06/14/16 11:20 PM
Its a TRAP!
Its a TRAP!
I sure did just jacked 30hrs of work.. in 30 seconds no less work laugh2
Just followed the advice given to me. Put a stop on the drill bit to be safe and to avoid what just happened. In my younger days I wouldn't have taken this so well. LOL. Now it's:
"C'est la vie".
