Porting iron P-car heads & whoops!
#2091458
06/13/16 10:44 PM
06/13/16 10:44 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Got about 30 hours on the intakes went to do the exhaust, and then I seen em.. AIR PUMP PORTS. ![rolleyes rolleyes](/ubbthreads/images/graemlins/custom/rolleyes.gif) So can they be epoxied? Or do I have to braze em shut? Also, just the outside ones, or the inside ones? Thanks.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Porting iron P-car heads & whoops!
[Re: DARTH V8Я]
#2091463
06/13/16 10:55 PM
06/13/16 10:55 PM
Posts: 561 USA
B3RE
USA
Got about 30 hours on the intakes went to do the exhaust, and then I seen em.. AIR PUMP PORTS. ![rolleyes rolleyes](/ubbthreads/images/graemlins/custom/rolleyes.gif) So can they be epoxied? Or do I have to braze em shut? Also, just the outside ones, or the inside ones? Thanks. Drill and tap the holes for a set screw that will sit below the flange surface. It's been a while since I did a set, but you might not have to drill if the hole size is right for tapping. Can't remember if it was 1/4" or 5/16".
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: DARTH V8Я]
#2091473
06/13/16 11:05 PM
06/13/16 11:05 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
The holes will take a 5/16th coarse tap. Thread them and put 5/16th set screws in them. I just did a set yesterday on the 360 going in my truck.
[Re: DARTH V8Я]
#2091905
06/14/16 05:00 PM
06/14/16 05:00 PM
fast68plymouth
So. Burlington, Vt.
30hrs grinding intake ports on OE iron heads??? Yikes!!! Noooooo thanks......
[Re: Polarapete]
#2091915
06/14/16 05:14 PM
06/14/16 05:14 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I have been doing the same to the heads that I have. I tapped 7 of them successfully using my 5/16 - 18 thread tap and then broke the tap in the hole on #8 ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I have now broken it off below the surface (it keeps crumbling) and resists easy removal. My next step is to use my Dremel and a tiny grinder bit to get all the rest of it out. I will use a proper pre drill bit and go up to a 3/8 - 16 tap on one hole in this head. Just a little hiccup in the process. I know better, I just wanted to hurry the process and it bit me in the A** Just heat the broken tap with a cutting torch and and give it a quick shot of oxygen. The broken tap will instantly vanish. Kevin
[Re: fast68plymouth]
#2091920
06/14/16 05:19 PM
06/14/16 05:19 PM
DARTH V8Я
Its a TRAP!
30hrs grinding intake ports on OE iron heads??? Yikes!!! Noooooo thanks...... Cause I don't have your skills ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Good thing I don't charge myself labor ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) #1 of 8 lol. So like this? What about the hole inside the port? Leave it? ![](http://i1224.photobucket.com/albums/ee380/ASYLUM_thirteen/air_zpsbswlxkrj.jpg)
[Re: Twostick]
#2091924
06/14/16 05:23 PM
06/14/16 05:23 PM
Posts: 8,357 fredericksburg,va
cudaman1969
fredericksburg,va
I have been doing the same to the heads that I have. I tapped 7 of them successfully using my 5/16 - 18 thread tap and then broke the tap in the hole on #8 ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I have now broken it off below the surface (it keeps crumbling) and resists easy removal. My next step is to use my Dremel and a tiny grinder bit to get all the rest of it out. I will use a proper pre drill bit and go up to a 3/8 - 16 tap on one hole in this head. Just a little hiccup in the process. I know better, I just wanted to hurry the process and it bit me in the A** Just heat the broken tap with a cutting torch and and give it a quick shot of oxygen. The broken tap will instantly vanish. Kevin Heat to what color? Heard this before on removing broken studs and things.
[Re: Twostick]
#2091948
06/14/16 06:02 PM
06/14/16 06:02 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have been doing the same to the heads that I have. I tapped 7 of them successfully using my 5/16 - 18 thread tap and then broke the tap in the hole on #8 ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I have now broken it off below the surface (it keeps crumbling) and resists easy removal. My next step is to use my Dremel and a tiny grinder bit to get all the rest of it out. I will use a proper pre drill bit and go up to a 3/8 - 16 tap on one hole in this head. Just a little hiccup in the process. I know better, I just wanted to hurry the process and it bit me in the A** Just heat the broken tap with a cutting torch and and give it a quick shot of oxygen. The broken tap will instantly vanish. Kevin I would do that if they were just cores and no great loss, but the heads had been through a machine shop, valves ground, PC stem seals on all valves etc. (the full treatment) are completely assembled and I don't want to heat the one and risk any further steps back. I will just get comfortable with the Dremel and work it out.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: DARTH V8Я]
#2091959
06/14/16 06:18 PM
06/14/16 06:18 PM
Posts: 4,457 Washington
madscientist
Washington
30hrs grinding intake ports on OE iron heads??? Yikes!!! Noooooo thanks...... Cause I don't have your skills ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Good thing I don't charge myself labor ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) #1 of 8 lol. So like this? What about the hole inside the port? Leave it? I grind the bump down and let it go. Just keep plugging the holes like you are.
[Re: madscientist]
#2091966
06/14/16 06:30 PM
06/14/16 06:30 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I still have a few sets of iron heads leaning against the wall in my garage but so far I have been smart enough not to touch them. I hope I stay smart enough for the rest of my life so my kids can scrap them after I'm dead.
[Re: pittsburghracer]
#2091983
06/14/16 06:59 PM
06/14/16 06:59 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
I just used spare/old bolts. Drill/tapped, bottomed them good, ground them off & flush. Buh-bye to dat. Those ports'll never get smog hdwr on any day.
#2091995
06/14/16 07:21 PM
06/14/16 07:21 PM
DARTH V8Я
Its a TRAP!
I still have a few sets of iron heads leaning against the wall in my garage but so far I have been smart enough not to touch them. I hope I stay smart enough for the rest of my life so my kids can scrap them after I'm dead. Calling me dumb? ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif) Seems about right! ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: DARTH V8Я]
#2092073
06/14/16 10:25 PM
06/14/16 10:25 PM
DARTH V8Я
Its a TRAP!
Calling me dumb? ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif) Seems about right! WAIT! I WAS right! Had a stop on the drill bit, and I hit water.. junk in 30 seconds. Well well well well.. what's Summits # again? ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: DARTH V8Я]
#2092090
06/14/16 10:48 PM
06/14/16 10:48 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Calling me dumb? ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif) Seems about right! WAIT! I WAS right! Had a stop on the drill bit, and I hit water.. junk in 30 seconds. Well well well well.. what's Summits # again? You are killing me over here. LOL I'm trying to get ready for a Mopar race weekend.
[Re: DARTH V8Я]
#2092122
06/14/16 11:20 PM
06/14/16 11:20 PM
DARTH V8Я
Its a TRAP!
I sure did just jacked 30hrs of work.. in 30 seconds no less ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) Just followed the advice given to me. Put a stop on the drill bit to be safe and to avoid what just happened. In my younger days I wouldn't have taken this so well. LOL. Now it's: "C'est la vie".
