Re: Looking for cam recommendations
[Re: Joes66dart]
#2091861
06/14/16 04:13 PM
06/14/16 04:13 PM
Posts: 4,457 Washington
madscientist
Washington
I old call someone who actually GRINDS cams and ask them. Phone calls are cheap today. I'd call several and get a feel for the one you get along with best.
Cam Motion Racer Brown Jones cams Bullet cams Erson cams Howard's cams
That is just a few I can think of.
I did not suggest comp. That was on purpose.
[Re: Joes66dart]
#2091883
06/14/16 04:36 PM
06/14/16 04:36 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Call Bullet and be armed with all the info
[Re: GTS340]
#2091902
06/14/16 04:57 PM
06/14/16 04:57 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Custom cam 110 degree lobe centers, something like Intake 310@.020 280@.050 200@.200 .465 lobe lift
Exhaust 324@.020 288@.050 204@.200 .465 lobe lift
But those springs do not have the seat pressure to suit such a cam, put a suitable PAC spring on there set .050 from coil bind at max lift
That's basically where I'd be as well. Maybe a little more intake lobe lift if you're changing springs.
[Re: madscientist]
#2091930
06/14/16 05:30 PM
06/14/16 05:30 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I old call someone who actually GRINDS cams and ask them. Phone calls are cheap today. I'd call several and get a feel for the one you get along with best. ISKY....... Cam Motion Racer Brown Jones cams Bullet cams Erson cams Howard's cams
[Re: GTS340]
#2092018
06/14/16 08:23 PM
06/14/16 08:23 PM
Posts: 287 PA
Harry's Taxi 2
PA
GTS340 Could I ask why you suggested a 110 lobe separation?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Harry's Taxi 2]
#2092033
06/14/16 09:04 PM
06/14/16 09:04 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
GTS340 Could I ask why you suggested a 110 lobe separation? Bracket car with a lot of stroke, wider lobe seperation will raise RPM where peak torque occurs and be less violent at the hit. Thats ASSuming that since its just a bracket car with big tires that the chassis isnt scienced out Additionally wider seperation lowers peak cylinder pressure which reduces chances of detonation
[Re: Joes66dart]
#2092107
06/14/16 11:02 PM
06/14/16 11:02 PM
Posts: 31,041 Oregon
AndyF
Thanks guys. After talking to a few people, I'm going to go with a comp. 23-709-9 That is a big boy cam. Comp recommends a lot more spring than what you have so you'll have to think about that.
[Re: Joes66dart]
#2092139
06/14/16 11:46 PM
06/14/16 11:46 PM
Posts: 188 Middletown, Ohio
Joes66dart
Middletown, Ohio
Andy, what springs would you recommend. I had one engine builder say he would use pac 1245 springs. My engine builder checked my springs and seems to think they will work.
[Re: Joes66dart]
#2092204
06/15/16 01:27 AM
06/15/16 01:27 AM
Posts: 10,007 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Ask about PAC 1226 springs. I suspect they might be a great fit for your cam.They are 275 @ 2.00, so with your cam they can be set at about 300 on the seat and be at about 1.950 installed height. They are a 1.625 double spring. This is the last place you want to try and save $$, it can cause you a lot of lost power and broken parts.
[Re: gregsdart]
#2092219
06/15/16 02:10 AM
06/15/16 02:10 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Ask about PAC 1226 springs. I suspect they might be a great fit for your cam.They are 275 @ 2.00, so with your cam they can be set at about 300 on the seat and be at about 1.950 installed height. They are a 1.625 double spring. This is the last place you want to try and save $$, it can cause you a lot of lost power and broken parts. PAC-1226 is a 1.55" diameter spring, but is 275 seat as mentioned. I'm running basically the same spring, the PAC-1326 which is a PAC-1226 that has been prepped for "enhanced durability", but my cam is only mid 270's duration and 0.726" lift.
