Looking for cam recommendations #2091801
06/14/16 02:39 PM
06/14/16 02:39 PM
Middletown, Ohio
Joes66dart Offline OP
Middletown, Ohio
Putting our new motor together and have to buy a new cam. Here a rundown
520 low deck
K1 4.375 crank
K1 6.535 rods
Je flat top pistons
Indy 440ez 325 cnc heads
Harland sharp 1.6 rockers
Kmotion 950 springs
Indy 4500 intake
1250 dominator on e85
Not sure on installed height of springs as of yet.
Car weighs 2950 race ready with driver, 14x32 tire, 5500 convertor, 727 Trans. Super pro car. 4 link, tube chassis.
Re: Looking for cam recommendations [Re: Joes66dart] #2091810
06/14/16 02:57 PM
06/14/16 02:57 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Compression? And are you wanting a low maintenance bracket cam or something aggressive?
Re: Looking for cam recommendations [Re: Joes66dart] #2091819
06/14/16 03:12 PM
06/14/16 03:12 PM
Middletown, Ohio
Middletown, Ohio
Compression is 13-1. It's a bracket car bUT we're looking for every ounce of power we can get
Re: Looking for cam recommendations [Re: Joes66dart] #2091844
06/14/16 03:51 PM
06/14/16 03:51 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Custom cam 110 degree lobe centers, something like
Intake
310@.020
280@.050
200@.200
.465 lobe lift
Exhaust
324@.020
288@.050
204@.200
.465 lobe lift
But those springs do not have the seat pressure to suit such a cam, put a suitable PAC spring on there set .050 from coil bind at max lift
Re: Looking for cam recommendations [Re: Joes66dart] #2091855
06/14/16 04:07 PM
06/14/16 04:07 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I agree with GTS340.
You will also need some really good pushrods too. 3/8" x 0.145" wall don't cost much more than the 0.120" wall.
If a larger diameter will fit, that would be even better.
Re: Looking for cam recommendations [Re: Joes66dart] #2091861
06/14/16 04:13 PM
06/14/16 04:13 PM
Washington
madscientist Offline
Washington
I old call someone who actually GRINDS cams and ask them. Phone calls are cheap today. I'd call several and get a feel for the one you get along with best.
Cam Motion
Racer Brown
Jones cams
Bullet cams
Erson cams
Howard's cams
That is just a few I can think of.
I did not suggest comp. That was on purpose.
Re: Looking for cam recommendations [Re: Joes66dart] #2091883
06/14/16 04:36 PM
06/14/16 04:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Call Bullet and be armed with all the info
Re: Looking for cam recommendations [Re: GTS340] #2091902
06/14/16 04:57 PM
06/14/16 04:57 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Intake
310@.020
280@.050
200@.200
.465 lobe lift
Exhaust
324@.020
288@.050
204@.200
.465 lobe lift
That's basically where I'd be as well.
Maybe a little more intake lobe lift if you're changing springs.
Re: Looking for cam recommendations [Re: madscientist] #2091930
06/14/16 05:30 PM
06/14/16 05:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
ISKY.......
Cam Motion
Racer Brown
Jones cams
Bullet cams
Erson cams
Howard's cams
Re: Looking for cam recommendations [Re: Joes66dart] #2091940
06/14/16 05:53 PM
06/14/16 05:53 PM
AndyF Offline
AndyF  Offline
The HS 1.60 shaft mounted rocker arms and the K950 springs will create a box that you have to work inside of. Basically you'll be limited to roughly .750 net lift with those springs or .470 lobe lift. Those spring might also limit the type of lobe that you can run but that is a little beyond me.
The .750 lift limit will constrain the amount of power that you can make so that is the trade off. If those are the parts that you're going with then pick a cam that fits the parts that you have and live with the results. If you want to make more power than that then you have to step up to more spring and maybe different rocker arms.
Re: Looking for cam recommendations [Re: GTS340] #2092018
06/14/16 08:23 PM
06/14/16 08:23 PM
PA
Harry's Taxi 2 Offline
PA
GTS340 Could I ask why you suggested a 110 lobe separation?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Looking for cam recommendations [Re: Harry's Taxi 2] #2092025
06/14/16 08:34 PM
06/14/16 08:34 PM
Middletown, Ohio
Middletown, Ohio
Thanks guys. After talking to a few people, I'm going to go with a comp. 23-709-9
Re: Looking for cam recommendations [Re: Harry's Taxi 2] #2092033
06/14/16 09:04 PM
06/14/16 09:04 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Bracket car with a lot of stroke, wider lobe seperation will raise RPM where peak torque occurs and be less violent at the hit. Thats ASSuming that since its just a bracket car with big tires that the chassis isnt scienced out
Additionally wider seperation lowers peak cylinder pressure which reduces chances of detonation
Re: Looking for cam recommendations [Re: Joes66dart] #2092107
06/14/16 11:02 PM
06/14/16 11:02 PM
AndyF Offline
AndyF  Offline
That is a big boy cam. Comp recommends a lot more spring than what you have so you'll have to think about that.
Re: Looking for cam recommendations [Re: Joes66dart] #2092139
06/14/16 11:46 PM
06/14/16 11:46 PM
Middletown, Ohio
Middletown, Ohio
Andy, what springs would you recommend. I had one engine builder say he would use pac 1245 springs. My engine builder checked my springs and seems to think they will work.
Re: Looking for cam recommendations [Re: Joes66dart] #2092204
06/15/16 01:27 AM
06/15/16 01:27 AM
gregsdart Offline
gregsdart  Offline
Ask about PAC 1226 springs. I suspect they might be a great fit for your cam.They are 275 @ 2.00, so with your cam they can be set at about 300 on the seat and be at about 1.950 installed height. They are a 1.625 double spring. This is the last place you want to try and save $$, it can cause you a lot of lost power and broken parts.
Re: Looking for cam recommendations [Re: gregsdart] #2092219
06/15/16 02:10 AM
06/15/16 02:10 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
PAC-1226 is a 1.55" diameter spring, but is 275 seat as mentioned.
I'm running basically the same spring, the PAC-1326 which is a PAC-1226 that has been prepped for "enhanced durability", but my cam is only mid 270's duration and 0.726" lift.
Re: Looking for cam recommendations [Re: Joes66dart] #2092278
06/15/16 09:44 AM
06/15/16 09:44 AM
gregsdart Offline
gregsdart  Offline
That cam you picked is very close to a couple I have run, both of which performed very well. Looking forward to results posts. up
