McLeod clutches #2091676
06/14/16 11:20 AM
06/14/16 11:20 AM
GA
Gerald l Offline OP
Gerald l  Offline OP
GA
Im about to get my low deck stroker installed and decided to just put in a new clutch since everything will be apart anyway. I came across these 2. Anyone have any experience with these? I thought about center force..seems to be a little cheaper but I hear mixed reviews. Some people love em and some people say they are too grabby and burn out too quickly
Clutch Kit, Super StreetPro, Organic, Ceramic, 1.0 in. Diameter Shaft, 23-Spline, 10.5 in. Diameter Disc, Kit - rated for 500hp
Or McLeod RST Street Twin Clutch Kit...rated for 800hp?
There's about a $300 difference so which one would be a better choice for a street driven car? I don't want to buy the more expensive one and be over compensating if the cheaper one will be just as good. I haven't dynoed the engine so I don't know the power numbers yet.
Re: McLeod clutches [Re: Gerald l] #2091685
06/14/16 11:32 AM
06/14/16 11:32 AM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
After vibration issues with a Centerforce Dual Friction, I went with a McLeod street clutch/disc. Have been very happy with it for years.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: McLeod clutches [Re: FM3AAR] #2091697
06/14/16 11:41 AM
06/14/16 11:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Same here, didn't care for the Centerforce Dual (overrated), McLeod is a much better choice/component
Re: McLeod clutches [Re: Gerald l] #2091718
06/14/16 12:13 PM
06/14/16 12:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
CF dual in my 65.Been in for 15 years.No problems ever and still hooks great.I did run McCleod B&Bs for years.But getting old 3200 pound was hard to use.My CF is light and hooks great.Ran Zoom and it was trash.Rocky
Chrysler Firepower
Re: McLeod clutches [Re: Gerald l] #2091734
06/14/16 12:27 PM
06/14/16 12:27 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I have older street twin McLeod in my car. Took a little to get used to, it is a bit heavier and seems to grab quickly, but I love it. Tech person at McLeod said it would last against my engine combo at the time.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: McLeod clutches [Re: therocks] #2091833
06/14/16 03:30 PM
06/14/16 03:30 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
CFDF here also. Been in for many years with no issues. Best bang for the buck as far as I'm concerned. I race with it and do a lot of street driving. At my age, I like the light pedal pressure and I also like the fact that it hooks...11" DF is rated at 580 lb/ft, while the CF DFX is rated at 625 lb/ft. The DFX is ceramic and is a touch grabby, but tolerable.
In any case make sure you either install a new flywheel or have the one you have now resurfaced.
Good luck.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: McLeod clutches [Re: Gerald l] #2091866
06/14/16 04:22 PM
06/14/16 04:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
68 mine is the same.People complain about diaphram clutch but I shift at 7200 with no problems.Rocky
Chrysler Firepower
Re: McLeod clutches [Re: Gerald l] #2091936
06/14/16 05:41 PM
06/14/16 05:41 PM
AndyF Offline
AndyF  Offline
Do you have an 8 bolt crank? I have a McLeod Street Twin that is new in the box that I'm not planning to use. I had it up for sale in the parts section but it hasn't sold yet.
Re: McLeod clutches [Re: therocks] #2092002
06/14/16 07:39 PM
06/14/16 07:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
we've installed a Butt load of CF clutches, only 1 had a problem, they did take care of it after a bit of arm twisting beer
Re: McLeod clutches [Re: AndyF] #2092110
06/14/16 11:04 PM
06/14/16 11:04 PM
GA
Gerald l Offline OP
Gerald l  Offline OP
GA
I believe it's a 6 bolt. I'll have to double check tomorrow
Re: McLeod clutches [Re: Gerald l] #2092127
06/14/16 11:29 PM
06/14/16 11:29 PM
tucson az
frank Offline
frank  Offline
tucson az
I went the McCloud with my 496 stroker. Engine makes 650 pounds of torque and no issues with the McCloud. I'm going to use another one in my nest project also
Re: McLeod clutches [Re: Gerald l] #2092154
06/15/16 12:01 AM
06/15/16 12:01 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have sworn by McLeod clutches and have never had a problem. You just need a strong left leg.
Re: McLeod clutches [Re: Gerald l] #2092631
06/15/16 07:34 PM
06/15/16 07:34 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I have had good experiences with both McLeod and Centerforce clutches. Used McLeod for years, tried a CF recently and I like it. Not sure, but my gut says I'll probably go CF on the next project.
Re: McLeod clutches [Re: Gerald l] #2092663
06/15/16 08:35 PM
06/15/16 08:35 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I have two CF, one in my Cuda works great, one in my Viper powered SRT-10 and I hate it. Only difference in the two is a hydraulic master/slave on the SRT steel flywheel, and fully mechanical on the Cuda Aluminum flywheel. I've used McLeod and they worked great in a 68 Hemi RR. The advice about the pressure plate is dead on.
Re: McLeod clutches [Re: Gerald l] #2092889
06/16/16 09:57 AM
06/16/16 09:57 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I have one in my 68 truck. No issues. I had to modify the fingers to allow for the larger input shaft. You can have them laser cut it for you before it gets to you (if necessary) but I didn't think about it before it was too late.
Re: McLeod clutches [Re: Gerald l] #2093262
06/17/16 12:04 AM
06/17/16 12:04 AM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I have used the Mcleod Rst and Rxt (twin disc) in my 4100lbs RR.
My first stroker motor made 550 torque 500 hp. I used the RST, and intermittently the clutch would slip. I took the clutch apart, and found glazing on the flywheel and discs.
I sent the clutch back to Mcleod, and they rebuilt it under warranty. They said for some reason the clutch never seated properly. I did perform the 500 miles break-in period.
Mcleod wanted me to use the RST again. Since I replaced the cam/intake on my motor, It now made 600 hp and 650 torque. I decide to use the RXT, and I am currently breaking it in. Breakin is very important.
The clutch feels very light. It's a pleasure to drive in heavy traffic. The pedal effort feels very close to a new car.
Centerforce did not recommend the DF for my setup because my car weight and power. I think they mentioned it was good for 500-550 hp in a 3500lbs car.
Re: McLeod clutches [Re: Gerald l] #2093273
06/17/16 12:24 AM
06/17/16 12:24 AM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
All we install are McLeods..
Tried 1 CF had major issues, tossed it in the dumpster..
R&R a clutch is too labor intense to use marginal parts..
Just my $0.02... wink
Re: McLeod clutches [Re: Sinitro] #2093313
06/17/16 01:58 AM
06/17/16 01:58 AM
we used the McLeod on the stock car once (360/iron bell/A230 3 sp) & it held up fine. granted it ain't drop the hammer drag race standing starts but it was mostly WOT in the straights & part throttle in the corners. on teardown the disc was burnt but no slippage
Re: McLeod clutches [Re: Gerald l] #2093381
06/17/16 09:15 AM
06/17/16 09:15 AM
NY
Beep Beep Offline
Beep Beep  Offline
NY
I forgot to mention the Rxt does eat up the flywheel because of the ceramic material. Mcleod said this is normal. I also do not have any clutch chatter.
Re: McLeod clutches [Re: Gerald l] #2096104
06/22/16 10:19 AM
06/22/16 10:19 AM
GA
Gerald l Offline OP
Gerald l  Offline OP
GA
Do I need to get the 130 or 143 tooth flywheel for the 400 motor with a 6 bolt crank?
