Big Block lifter bore bushings??? #2090710
06/12/16 04:22 PM
06/12/16 04:22 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Any know of a place local to Dallas TX that can bush lifter bores for an aluminum Hemi?
Thanks in advance.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2090808
06/12/16 07:30 PM
06/12/16 07:30 PM
AndyF Offline
AndyF  Offline
Reher Morrison can probably do most anything to an engine block. If they can't they would know someone who could.
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2090849
06/12/16 09:04 PM
06/12/16 09:04 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I was told by a friend Reher Morrison will not touch a Mopar. I need to call them to find out myself.
Doug
MOPAR or NO CAR!!!
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2090906
06/12/16 10:46 PM
06/12/16 10:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Reher and Morrison will happily do it. The build engines for SS/AH I'm sure lifter bushings are a no brainer for them..
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2090996
06/13/16 12:50 AM
06/13/16 12:50 AM
Does your freind drive a Chevy or Ford if not does he not want you to have better parts than he has whistling grin
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2091033
06/13/16 02:41 AM
06/13/16 02:41 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Somebody told you wrong. They will work on anything......plus they have a very good AH program as well
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2091047
06/13/16 03:54 AM
06/13/16 03:54 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Great. Thanks for the replies. I will call them this week.
Doug
MOPAR or NO CAR!!!
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2091120
06/13/16 11:25 AM
06/13/16 11:25 AM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
depends on what your meaning of "local" is
Terry Haddock at Lone Star Aluminum Block Repair in Temple, Tx
Joe
Without Data, you’re just another guy with an opinion.
Re: Big Block lifter bore bushings??? [Re: sr4440] #2091188
06/13/16 01:21 PM
06/13/16 01:21 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thanks, No problem driving for quality work. Reher Morrison said they would need to check to see if they have the set up and would call me back.
Doug
MOPAR or NO CAR!!!
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2091198
06/13/16 01:30 PM
06/13/16 01:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Cannot imagine they don't have the jigs as they do AH stuff...
Re: Big Block lifter bore bushings??? [Re: Al_Alguire] #2091299
06/13/16 05:30 PM
06/13/16 05:30 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I agree Al but I'm waiting for a phone call back.
Doug
MOPAR or NO CAR!!!
Re: Big Block lifter bore bushings??? [Re: Al_Alguire] #2091732
06/14/16 12:25 PM
06/14/16 12:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm thinking AH blocks get something non stock for lifter bore angles?
But if they have a CNC, which I assume they would, it should be no problem to get the right program ???
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2091736
06/14/16 12:32 PM
06/14/16 12:32 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The have many CNC machines. It I a very large place with a number of dyno cells as well. Last time I was there they had a Mildon Block Hemi sitting in the showroom. They do Heberts AH stuff as well.
Re: Big Block lifter bore bushings??? [Re: 65 Hemi] #2091799
06/14/16 02:31 PM
06/14/16 02:31 PM
AndyF Offline
AndyF  Offline
No doubt that RM can do the work but I don't have any idea if they want to or how backed up they are or anything like that. But if RM wanted to convert a Hemi to be an OHC engine they could make it happen.
