Alkey Runners got another ? for you #209042
01/30/09 11:55 PM
01/30/09 11:55 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
I was talking to my engine builder today and he said I can not run a conventional oil filter, he said the alcohol will dissolve glue in the filter and contaminate the oil? What filter do you guys run?
Here are a couple of pic of the new bullit for "La Putita" we are almost there!
Diego
Re: Alkey Runners got another ? for you [Re: Diego_Ted] #209043
01/31/09 12:39 AM
01/31/09 12:39 AM
NJ
arc Offline
arc  Offline
NJ
system one
Re: Alkey Runners got another ? for you [Re: Diego_Ted] #209044
01/31/09 12:40 AM
01/31/09 12:40 AM
Utah
dragnduster Offline
dragnduster  Offline
Utah
Ted, I just run a Fram HP-1 and have for many years. Haven't had any issues with them. Are you bringing "La Putita" to MATS?
Re: Alkey Runners got another ? for you [Re: dragnduster] #209045
01/31/09 12:47 AM
01/31/09 12:47 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well another vote for System One...I know a guy with one
Re: Alkey Runners got another ? for you [Re: Diego_Ted] #209046
01/31/09 01:28 AM
01/31/09 01:28 AM
System One or Oberg(Oberg has a new name that I can't remember) there a heavy duty stainless steel screen remote mounted oil filter that is cleanable and reusable and they are easeir to use and clean than the System One brand. The down side of the Oberg types is you have to mount them remotely and run hoses to and back, more money in other words and there probally more money to start with than the System Ones are Ted, which heads are those, Indy EZ or what?
Re: Alkey Runners got another ? for you [Re: Cab_Burge] #209047
01/31/09 11:24 AM
01/31/09 11:24 AM
Diego-Town, CA
Diego-Town, CA
Thanks guys, now is it TRUE the Alky in the oil could cuase the others to fail?
Dave, Yes La Putita is what is going to MATS.
Cab those are Ezs.
Diego
Re: Alkey Runners got another ? for you [Re: Diego_Ted] #209048
01/31/09 12:15 PM
01/31/09 12:15 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
Ted I'm glad to see you will be going to MATS. I personally have never heard of alky in the oil causing filter problems. If the budget allows it I would say go with the System One just to be safe . How much is the alky going for in your area now?
Re: Alkey Runners got another ? for you [Re: dragnduster] #209049
01/31/09 04:29 PM
01/31/09 04:29 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Store bought filter for 7 years on alky. No problems.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Alkey Runners got another ? for you [Re: Irun5snd8th] #209050
01/31/09 06:25 PM
01/31/09 06:25 PM
Diego-Town, CA
Diego-Town, CA
Glad to hear it Which filter do you run?
Ted
Re: Alkey Runners got another ? for you [Re: Diego_Ted] #209051
01/31/09 06:45 PM
01/31/09 06:45 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I run a 20195 Purolator filter.
Re: Alkey Runners got another ? for you [Re: Diego_Ted] #209052
01/31/09 06:45 PM
01/31/09 06:45 PM
Ames, Iowa
LoneMopar Offline
LoneMopar  Offline
Ames, Iowa
Wix 51515R for 2 years.
I have cut a few of them apart and have not seen any alcohol damage.
Re: Alkey Runners got another ? for you [Re: LoneMopar] #209053
01/31/09 09:32 PM
01/31/09 09:32 PM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
wix for me since 1997 why would an engine runing alcohol hurt it unless your filtering alcohol with it. if your getting alcohol in your oil you got it too fat and or your rings are shot your oil will actually last longer on alcohol the key is oil temp to evaporate the moisture that accumulates fron oil hitting cold intake cylinder head runners and sweating moisture is also the problem with corrosion in the fuel and induction system if the moisture is controled crossion is not a problem let it get out of hand and everthing will corrode fuel pumps carbs intakes heads cylinders but if you keep your fuel dry use a good top lube and get the engine up to reasonable operating temp 180 to 190 degrees 210 to 220 before shutting it down for the day you will have almost no noticable corrosion and oil will last along time.
Re: Alkey Runners got another ? for you [Re: W2DODGE] #209054
02/01/09 12:45 AM
02/01/09 12:45 AM
Diego-Town, CA
Diego-Town, CA
Thx guys lots of great info, Big learning curve for me.
Ted
Re: Alkey Runners got another ? for you [Re: Diego_Ted] #209055
02/01/09 07:57 AM
02/01/09 07:57 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Wix here also. If he was talking about fuel filters he is right, you need a stainless steel filtering element, not paper.
Re: Alkey Runners got another ? for you [Re: MegaDart] #209056
02/01/09 09:59 AM
02/01/09 09:59 AM
Mobile Al
Dale Offline
Dale  Offline
Mobile Al
I've had my system 1 for 15 years more than paid for itself and actually had a bearing problem last year and it Caught all of it.
Re: Alkey Runners got another ? for you [Re: LoneMopar] #209057
02/01/09 10:45 AM
02/01/09 10:45 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Re: Alkey Runners got another ? for you [Re: mac56] #209058
02/01/09 11:34 AM
02/01/09 11:34 AM
O'Fallon,IL.
70RTRacer Offline
70RTRacer  Offline
O'Fallon,IL.
Wix ! No problems since the mid 80's. God i'm old.
Re: Alkey Runners got another ? for you [Re: 70RTRacer] #209059
02/04/09 11:44 PM
02/04/09 11:44 PM
Diego-Town, CA
Diego-Town, CA
