Page 2 of 3 1 2 3
Re: Blown Head Gasket & More.... Ugghh! [Re: MR_P_BODY] #2088805
06/09/16 01:09 AM
06/09/16 01:09 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Originally Posted By MR_P_BODY
Myself... I'd be looking at the edge of the
gasket to the tapper on the bore... so look
closely at that point BEFORE you even pull the
gasket(hopefully it stays on the block)
wave
iagree
The 1009 Felpro overhangs the chamfer on the bore of a lot of BB Mopars especially late model ones. I don't know how they sell any of them.
Kevin
Re: Blown Head Gasket & More.... Ugghh! [Re: Twostick] #2089003
06/09/16 12:43 PM
06/09/16 12:43 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
wave
iagree
Kevin
They probably fit great on 4.25 bore engines ... wink
Re: Blown Head Gasket & More.... Ugghh! [Re: BradH] #2089005
06/09/16 12:44 PM
06/09/16 12:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted By BradH
Originally Posted By Chris2342
Probably their (440 source) white gaskets that were made by Corteco.
The original orange Detroit Gasket .040" race gaskets, and the later version in the same size that was updated to an easier-to-disassemble white coating before Corteco bought DG, are very good.
I have suspected the .051" version that 440 Source sold (sells?) is a standard replacement gasket (think along the lines of the basic Fel-Pro Permatorque), not the more durable race-type part.
I sold a local customer a set of Indy EZ heads to replace his mega-cracked ported 452 heads.
I had a couple of sets of "edelbrock" head gasket sets here, which at the time were the white Corteco .051 thick ones.
Blew a couple chunks out of them after only a couple of passes.
They didn't show any signs of being compressed at all.
There was no evidence of any other problems, and the motor had no issues with the steel shims that had been used with the iron heads.
I got him some Cometics, and it never bothered again.
IMO, those white Corteco gaskets fall into the "junk" catagory.
I wouldn't use them on anything after seeing them fail that quickly.
Re: Blown Head Gasket & More.... Ugghh! [Re: BradH] #2089039
06/09/16 01:17 PM
06/09/16 01:17 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Is an .039 gasket safe with a zero-deck build? These seem to fit the bill for a .040 over 400 block (4.38 bore):
http://www.summitracing.com/parts/fel-1009/overview/make/chrysler
Re: Blown Head Gasket & More.... Ugghh! [Re: JohnRR] #2089049
06/09/16 01:40 PM
06/09/16 01:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
wave
iagree
Kevin
The 1009 gasket fits a 4.375" bore perfectly, but has NO room for error re: excessive chamfer at the top of the bore. I ran them w/o any issues for years at that bore size w/ my old ported OEM iron heads. If they hang over the edge, they're toast.
Re: Blown Head Gasket & More.... Ugghh! [Re: fast68plymouth] #2089053
06/09/16 01:48 PM
06/09/16 01:48 PM
BradH Offline
BradH  Offline
That's disappointing to hear... I had been told the only difference between the white ones and original orange DG gaskets was that the white coating disassembled easier. FWIW, the ones I have of both early & late style all measure the same uncompressed thickness of around .042".
The orange ones, which are all that I ever used w/ my Stage VI heads, left a good bit of the surface coating on both the head & deck surfaces, which was a PITA to clean off. But they didn't have any sealing or durability issues that I encountered.
I have a few sets of the orange DG-made ones still on hand simply because I had good results with them and bought some that I found in a vendor's remaining stock. They have a 4.41" bore and measure right about .040" compressed, and don't brinell the heads, either. 440Jim used them on some of his old builds, too, before going to Cometics.
I also bought two pairs of the discontinued white ones that Edelbrock sold under their gasket line because I thought they were the "improved" version. Sure doesn't sound like it after what you just said. down Have never run the white ones myself, only the orange ones.
Re: Blown Head Gasket & More.... Ugghh! [Re: StealthWedge67] #2089054
06/09/16 01:51 PM
06/09/16 01:51 PM
BradH Offline
BradH  Offline
Per my comment above on the other thread that mentions the Fel-Pro 1009, NO.
From my experience, they're totally maxed out on bore size at 4.375". Even then, the bores need to not have any obvious chamfer at the top that allows that gasket to extend into combustion zone.
Re: Blown Head Gasket & More.... Ugghh! [Re: Polarapete] #2089056
06/09/16 01:56 PM
06/09/16 01:56 PM
Puyallup, WA
Puyallup, WA
Originally Posted By Polarapete
I live close to you and I have a Cab Burge built 440 that needs to have it's muscles exercised. I have had it since 2012 and have never fired it. Send me a PM if you are interested and we will talk.
Thanks for the offer Pete, but I'm not interested in a new motor, especially not an RB. My 451 still should be just fine once I get this issue sorted out. And I its a really good fit for this car.
Re: Blown Head Gasket & More.... Ugghh! [Re: StealthWedge67] #2089059
06/09/16 02:01 PM
06/09/16 02:01 PM
Puyallup, WA
Puyallup, WA
Sorry Brad, I missed your reference to the 1009. I'll keep looking at options.
Re: Blown Head Gasket & More.... Ugghh! [Re: StealthWedge67] #2089063
06/09/16 02:10 PM
06/09/16 02:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
I've had a few motors come through the shop that torched 1009's because of some bore overhang.
I simply won't use them on a 440/400 based engine anymore(haven't in years).
They are fine on 383/426 based motors though, as long as they are big enough to be out past the perimeter of the chamber.
For the most part, if it's a 440/400 based motor and I think it needs a better gasket than a Fel-Pro 8519, then it gets Cometics.
Re: Blown Head Gasket & More.... Ugghh! [Re: fast68plymouth] #2089082
06/09/16 02:46 PM
06/09/16 02:46 PM
BradH Offline
BradH  Offline
What do you consider the limit for the FP 8519PT? I have a set I use only for mockups, but never new if they're anything that could be used for my own builds. They strike me as kind of... marginal.
Re: Blown Head Gasket & More.... Ugghh! [Re: BradH] #2089090
06/09/16 02:54 PM
06/09/16 02:54 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Without regards to the actual gasket in question itself/the bore size, in general a .039 thick gasket is good for a 0 deck build as far as piston to head clearance goes. Thats why everyone tries to build 0 deck and use a .039 gasket, it gives you good quench while still running a safe piston to head clearance.
Re: Blown Head Gasket & More.... Ugghh! [Re: StealthWedge67] #2089095
06/09/16 03:01 PM
06/09/16 03:01 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Actually, I was going to loan it to you, not sell it. I do understand the fit issue because the RB motor takes up more room than the low deck. I don't have that problem in my project and could fit anything. We would have had to come up with an oiling system to fit your chassis, because my motor has an external pickup and pan for the truck chassis and that would not work for you. Good luck to you.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Blown Head Gasket & More.... Ugghh! [Re: BradH] #2089150
06/09/16 04:07 PM
06/09/16 04:07 PM
Az
Crizila Offline
Crizila  Offline
Az
Using head gaskets that over hang the bores is a pretty obvious build mistake, and quick death if you are using a composite gasket ( verses MLS ). Never seen a bore that didn't have some chamfer. The problem is all chamfers aint the same ( pic ). Yes, those are factory chamfers on a .040 bore. Horrible! Went with MLS Cometics sized to the worse hole ( pic ) as the best solution. Something for the OP to look at during failure analysis. Still choking a bit on the "time to failure" thing.
Fastest 300
Re: Blown Head Gasket & More.... Ugghh! [Re: StealthWedge67] #2089202
06/09/16 05:45 PM
06/09/16 05:45 PM
P
Paul_Fancsali Offline
P
Check it out with pressure tester then pull it down I would only fix the head gasket and then change oil a couple times in next 200 miles or so I have fixed many a blown head gasket and never pulled engine due to one unless rod is bent etc
Re: Blown Head Gasket & More.... Ugghh! [Re: BradH] #2089236
06/09/16 06:35 PM
06/09/16 06:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
Generally, street/strip motors that lean more towards the street side of things, up to around 550hp or so.
I've never had one fail on a motor I put together(none that I know of anyway).
I even put them on an 11.5:1 448 with EZ CNC 295 heads that made 675hp+.
Afaik they lived in that motor okay, but I don't think it saw that much use.
I wouldn't use them in that application nowadays, but I showed no fear at the time.
Re: Blown Head Gasket & More.... Ugghh! [Re: Paul_Fancsali] #2089237
06/09/16 06:37 PM
06/09/16 06:37 PM
an8sec70cuda Offline
iagree If you didn't drive the thing for a long time w/ the water and oil mixing, I'd pull the head and fix the gasket issue. Then change the oil, run it a while, change it again, etc.
It's easy enough to check for a bent rod w/ the motor in the car.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Blown Head Gasket & More.... Ugghh! [Re: StealthWedge67] #2089264
06/09/16 07:20 PM
06/09/16 07:20 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
would just cranking the motor over with the starter be enough to bend a rod?
Re: Blown Head Gasket & More.... Ugghh! [Re: StealthWedge67] #2089733
06/10/16 05:34 PM
06/10/16 05:34 PM
P
P
Most of suggestions are legit but this gentleman sounds like money is the issue? That's why I would do it the easy way and only take it apart if I had to beyond the head gasket. I also hate taking a car apart and not finishing it I have seen one to many fall threw the cracks and end up hanger queens or back yard I will get to it someday and rust away
Re: Blown Head Gasket & More.... Ugghh! [Re: krautrock] #2089759
06/10/16 06:46 PM
06/10/16 06:46 PM
Cab_Burge Online work
Cab_Burge  Online Work
Yes, you betcha whineyI saw that happen while working in a service station on a customers car back in 1963, the owners Son squirted a small amount of water down the carb. with the air cleaner off while the onwer of the car was trying to start the then new 1962 Pontiac Grand Prix puke We had steamed clean the motor and it was not starting right away due to moisture in the distributor cap, it bent the 3rd rod back on the passenger side and seized the motor up shruggy
Page 2 of 3 1 2 3
