performance converter in late 400 (1978) #208877
01/30/09 07:33 PM
01/30/09 07:33 PM
California
court9155 Offline OP
California
Hey guys. I used the search function until my eyes bled. I need some help here.
I have a 66 dodge charger that I am in the process of installing a 400 into. This is a 78 400 with a cast crank (external balance). The transmission I am using is a 1970 trans out of an imperial.
I have no torque converter. I do have the flexplate ( on the motor,400) but no converter.
I am very concerned because this is an external balance motor that I will have issues with vibrations.
I want a 1800-2000 stall converter that wont break the bank. Any ideas?
I looked at summit and hughes but man hughes converters are pricey.
This is just a cruiser and it only got the big block because that is what I have and it runs great and the original poly motor is out and in storage but it was shot.
Please advise.
Thanks.
Dan
67 charger
Re: performance converter in late 400 (1978) [Re: court9155] #208878
01/30/09 07:52 PM
01/30/09 07:52 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The 400 motor definitely needs external balance, the most practical way to handle this is with an aftermarket flexplate like the B&M #10237.
If the motor is stock and you won't be flogging it you might consider a rebuilt factory high-stall 10 3/4" converter; this will give you the stall you're looking for without breaking the bank. In some cases these converters will have the correct weight so it can use the stock flexplate.
Re: performance converter in late 400 (1978) [Re: court9155] #208879
01/30/09 07:57 PM
01/30/09 07:57 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Use the B&M flexplate part # 10237 that is designed to work on externally balanced 400 like yours,then use any convertor of your choice..
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: performance converter in late 400 (1978) [Re: court9155] #208880
01/30/09 08:36 PM
01/30/09 08:36 PM
California
California
Thanks guys!
I just use that and a converter for a forged crank motor??
67 charger
Re: performance converter in late 400 (1978) [Re: court9155] #208881
01/30/09 08:44 PM
01/30/09 08:44 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you buy the weighted B&M flexplate(a very good idea IMO) make sure you buy a neutral balance(sometimes called zero balance) converter.
weighted flexplate + unweighted converter = good
stock flexplate(unweighted) + weighted converter = good
any other combo = bad.
Re: performance converter in late 400 (1978) [Re: DaytonaTurbo] #208882
01/30/09 08:47 PM
01/30/09 08:47 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Shoot, I have a 2200 cheapy on my van. It is nice. A putt around and hammer it everyonce in a while one @ 2500 street car would be neat!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
