performance converter in late 400 (1978)
#208877
01/30/09 07:33 PM
01/30/09 07:33 PM
Posts: 301 California
court9155
California
Hey guys. I used the search function until my eyes bled. I need some help here.
I have a 66 dodge charger that I am in the process of installing a 400 into. This is a 78 400 with a cast crank (external balance). The transmission I am using is a 1970 trans out of an imperial.
I have no torque converter. I do have the flexplate ( on the motor,400) but no converter.
I am very concerned because this is an external balance motor that I will have issues with vibrations.
I want a 1800-2000 stall converter that wont break the bank. Any ideas?
I looked at summit and hughes but man hughes converters are pricey.
This is just a cruiser and it only got the big block because that is what I have and it runs great and the original poly motor is out and in storage but it was shot.
Please advise.
Thanks.
Dan
67 charger
Re: performance converter in late 400 (1978)
[Re: court9155]
#208878
01/30/09 07:52 PM
01/30/09 07:52 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The 400 motor definitely needs external balance, the most practical way to handle this is with an aftermarket flexplate like the B&M #10237.
If the motor is stock and you won't be flogging it you might consider a rebuilt factory high-stall 10 3/4" converter; this will give you the stall you're looking for without breaking the bank. In some cases these converters will have the correct weight so it can use the stock flexplate.
[Re: court9155]
#208879
01/30/09 07:57 PM
01/30/09 07:57 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Use the B&M flexplate part # 10237 that is designed to work on externally balanced 400 like yours,then use any convertor of your choice..
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: court9155]
#208880
01/30/09 08:36 PM
01/30/09 08:36 PM
court9155
California
Thanks guys!
I just use that and a converter for a forged crank motor??
67 charger
[Re: DaytonaTurbo]
#208882
01/30/09 08:47 PM
01/30/09 08:47 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Shoot, I have a 2200 cheapy on my van. It is nice. A putt around and hammer it everyonce in a while one @ 2500 street car would be neat!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
