Re: 1954 Chrysler front wheel swap
[Re: Slipknot440]
#2087302
06/06/16 08:34 PM
06/06/16 08:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You you have an alignment pin on the hub? My 38 Plymouth used wheel bolts too but had a pin to align the wheel in place while you bolted it up.
You can remove the pin and use any wheel that still uses the conical seat like the original rim. If you want to go with a shank type mag wheel then you have to run studs.
[Re: Slipknot440]
#2087322
06/06/16 08:57 PM
06/06/16 08:57 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
AZ_A12_BEE had went through something similar from memory on his 37 pickup... From memory he drilled out the fronts to the correct size to use normal pressed in studs. (it had a non stock rear diff anyways IIRC)
[Re: Slipknot440]
#2087385
06/06/16 10:43 PM
06/06/16 10:43 PM
Posts: 5,886 ohio
ruderunner
ohio
What type of rims do you want to install?
Angry white pureblood male
[Re: Slipknot440]
#2087670
06/07/16 12:08 PM
06/07/16 12:08 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
They used to make lug studs.I had a set on the early straight axle I had on my 65.Then I ran Cragars.Rocky
Chrysler Firepower
[Re: Slipknot440]
#2088271
06/08/16 12:00 PM
06/08/16 12:00 PM
therocks
Niles , Ohio
Cragar used to make left hands.That was like in the 70s though.I thought I might have saved the ones I had but its been 40 years since Ive seen them.Rocky
Chrysler Firepower
[Re: Slipknot440]
#2088662
06/08/16 10:45 PM
06/08/16 10:45 PM
therocks
Niles , Ohio
Nice looking. Check them after a few miles.Mine would losen at times even with locktite.Rocky
Chrysler Firepower
[Re: therocks]
#2089116
06/09/16 03:18 PM
06/09/16 03:18 PM
dogdays
