Will a '73 Dart 4dr sedan hood fit a '74 Dart Sport?? #2086690
06/05/16 10:12 PM
06/05/16 10:12 PM
Graham, WA
P
Polarapete Offline OP
P
Graham, WA
I have not worked at a wrecking yard since 1986 and no longer have easy access to a Hollander Interchange Manual so I need to know for a friend what hood will fit his Dart Sport. We built a Cold Air Induction system for his car and while the scoops are open they don't allow him to get much benefit from the system. He has a mild 360 on a high rise with a Quick Fuel 650 cfm double pump carb. He runs w/o an air filter at the track and it is so close to the hood that he cannot even use a proper vent tube for the fuel bowls. I found a '73 Dart being parted out and think the hood would probably fit his car. We could then cut up the Dart hood and bond a proper scoop that will allow more air and a big air filter. He could then keep his original hood stock in case he wanted to sell the car and I have plenty of room to store it at my shop. So will it fit and what is the model year range if that one gets sold??
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Will a '73 Dart 4dr sedan hood fit a '74 Dart Sport?? [Re: Polarapete] #2086784
06/06/16 01:02 AM
06/06/16 01:02 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
same hood
5549 post on old board
Re: Will a '73 Dart 4dr sedan hood fit a '74 Dart Sport?? [Re: 05dakota] #2086879
06/06/16 09:43 AM
06/06/16 09:43 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
So will a 69 Barracuda... wave
JB Rhinehart, Realist
A-Body's RULE!
Re: Will a '73 Dart 4dr sedan hood fit a '74 Dart Sport?? [Re: Rhinodart] #2087047
06/06/16 02:23 PM
06/06/16 02:23 PM
Locomotion Offline
Locomotion  Offline
As mentioned, '69 Barracuda and any '73 through '76 Dart hood will interchange. This includes a '76 Dart Lite hood with the aluminum underside framework. But you'd need lighter hood springs for that one because it weighs 10-15lbs less than an all-steel version.
