Cam Expert? #2085694
06/04/16 02:22 AM
06/04/16 02:22 AM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
I'm talking with a comp cams tech guy about a new cam.
I'm saying the heads see add'l flow until just over 0.70 lift and I don't want to rev past 6500 so there is little point in a large duration. I said I could go hydraulic or solid. So he comes back with a recommendation for 0.52. I asked why not 0.66? I even sent him the head flow table. He said, no you'll need to give me a lot more than 300 duration and if you use solid instead of hydraulic, that will be even tougher.
There are high lift cams with duration under 300, which allows the sweet spot to be a reasonable rpm range. And solid is not a step backwards if higher lift is desired, right? There is such a thing as a high lift, low duration cam for big blocks. I need to ask for the level 2 tech? What do you think? Or I need to hit the books again because I missed something?
Re: Cam Expert? [Re: Scott440] #2085749
06/04/16 09:31 AM
06/04/16 09:31 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you're looking for a cam recommendation from here, you need to provide as much info as you can about the combination and the application.
Re: Cam Expert? [Re: Scott440] #2085760
06/04/16 10:16 AM
06/04/16 10:16 AM
gregsdart Offline
gregsdart  Offline
Duration , lifter diameter , and rocker ratio limit the max lift that can be ground into a cam. For better lift numbers, a 1.7 ratio rocker will help.
Re: Cam Expert? [Re: Scott440] #2085796
06/04/16 11:59 AM
06/04/16 11:59 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I would look up the lobes in their master catalog and order a custom cam.
http://www.compcams.com/Technical/Catalogs/LC2007/2007LobeCatalog.pdf
Joe
Without Data, you’re just another guy with an opinion.
Re: Cam Expert? [Re: Scott440] #2085802
06/04/16 12:09 PM
06/04/16 12:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Call Dwayne Porter. Fast68plymouth on here.
Do it once, do it right. He is a comp cams dealer and knows his stuff. Has been dead on with my cams over the years.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Cam Expert? [Re: Scott440] #2085805
06/04/16 12:25 PM
06/04/16 12:25 PM
Az
Crizila Offline
Crizila  Offline
Az
Get more than 1 opinion. Lots of cam mfg's out there and they all have cam forms on line that you should be filling out and sending in with as much info as you can give them. Don't just rely on the head flow #'s and where the port stalls as a cam purchasing criteria. Gather as much info as you can so you can make an "educated GUESS".
Fastest 300
Re: Cam Expert? [Re: sr4440] #2085818
06/04/16 12:59 PM
06/04/16 12:59 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Joe
^ yeah
see page 35 in the catalog, the MM solid cams, probably the most lift in a solid you will find.
i would call dwayne and ask his opinion though...
Re: Cam Expert? [Re: B3422W5] #2086150
06/05/16 01:17 AM
06/05/16 01:17 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
If you call comp 5 times,you'll get 5 different cams.Comp has a fine product,,,,Call Dwayne and have no regrets whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Cam Expert? [Re: Scott440] #2086187
06/05/16 02:58 AM
06/05/16 02:58 AM
New Mexico
Scott440 Offline OP
Scott440  Offline OP
New Mexico
Not looking for a specific cam here -- just thinking I need a better tech and wondering if you guys thought the same. Sounds like, yes. I'll give Dwayne a call. Thanks.
