Page 4 of 4 1 2 3 4
Re: Magnum conversion harness. [Re: Bzzzz] #235903
06/21/13 03:19 AM
06/21/13 03:19 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
what about the non viper V10 truck engines? are you doing anything for those ?
AND WHAT WOULD YOU PUT ONE OF THOSE ANKERS IN ?? I CANT IMAGINE WHAT ONE OF THOSE WEIGHS,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Magnum conversion harness. [Re: fstfish66] #235904
06/21/13 08:17 PM
06/21/13 08:17 PM
Wisconsin,USA
Bzzzz Offline
Bzzzz  Offline
Wisconsin,USA
an old Jeep wagoneer
2005 Dodge 1500 Slt Hemi
2008 Chrysler PT cruiser
1984 Dodge D250
1978 Dodge D100 Adventurer
1964 Meyers Manx Dunebuggy
Re: Magnum conversion harness. [Re: wldtm] #2086050
06/04/16 09:04 PM
06/04/16 09:04 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I know I am dragging this up from the dead, but WLTDM'S PM box is full.
Is anyone currently selling the magnum conversion wiring harness?
Re: Magnum conversion harness. [Re: mgoblue9798] #2086145
06/05/16 12:57 AM
06/05/16 12:57 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I can't speak for the quality, but, HotwireAuto lists one....
Wiring Linky.
shruggy
John
Re: Magnum conversion harness. [Re: Cheeto] #2086173
06/05/16 01:57 AM
06/05/16 01:57 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
$930 for the hot rod version, wow. I can buy a running magnum for less than that and mod the factory harness if need be.
Don't be the exception.
Re: Magnum conversion harness. [Re: Supercuda] #2090430
06/12/16 02:13 AM
06/12/16 02:13 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yea, my son and I had that same thought when he decided to install a 5.9 with the electronic trans into his 57 Dodge wagon. He bought a running motor, trans, factory wiring harness and computer.
I've rewired several cars in my time, and I have adapted a coupe of efi throttle body systems to older cars, wiring in not new to me.
That said, I spent many hours between the factory wiring diagrams and the actual wiring harness trying to determine what I could eliminate (not using the dash or overhead monitoring consul), and trying to reduce the process to one fuse box. In the end, I came to the determination that if it would work, it would be great, but if a problem devolved, I would have no way of knowing what I may, or may not have done wrong.
My son finally bought the Hot Wire Kit. We had 4 wires to connect to make the motor run, it came with a fuse box, and there were feeds built into the harness to power several options. Best of all, there is a real person on the tech line, if you have a question or an issue. We had one we created ourselves, and they helped walk us through fixing our mistake. We should have done that from the start, it would have moved the car building process forward by several months.
I guess you need to determine what things you "farm out" on your project, and what you do yourself. A custom engine harness on a computer controlled motor and trans is a pretty complex part of a large project that many would be overwhelmed by. I can wire the car, give me a free standing functioning engine harness, which Hot Wire has done. Gene
Page 4 of 4 1 2 3 4
