Re: Cam Expert?
[Re: Scott440]
#2085802
06/04/16 12:09 PM
06/04/16 12:09 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Call Dwayne Porter. Fast68plymouth on here. Do it once, do it right. He is a comp cams dealer and knows his stuff. Has been dead on with my cams over the years.
Re: Cam Expert?
[Re: Scott440]
#2085805
06/04/16 12:25 PM
06/04/16 12:25 PM
Posts: 7,506 Az
Crizila
Az
Get more than 1 opinion. Lots of cam mfg's out there and they all have cam forms on line that you should be filling out and sending in with as much info as you can give them. Don't just rely on the head flow #'s and where the port stalls as a cam purchasing criteria. Gather as much info as you can so you can make an "educated GUESS".
Fastest 300
Re: Cam Expert?
[Re: sr4440]
#2085818
06/04/16 12:59 PM
06/04/16 12:59 PM
Posts: 2,094 central texas
krautrock
central texas
^ yeah see page 35 in the catalog, the MM solid cams, probably the most lift in a solid you will find. i would call dwayne and ask his opinion though...
Re: Cam Expert?
[Re: B3422W5]
#2086150
06/05/16 01:17 AM
06/05/16 01:17 AM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
Call Dwayne Porter. Fast68plymouth on here. Do it once, do it right. He is a comp cams dealer and knows his stuff. Has been dead on with my cams over the years. If you call comp 5 times,you'll get 5 different cams.Comp has a fine product,,,,Call Dwayne and have no regrets
