Re: Help with mini starter and positive battery cable fittment
[Re: 71rm23]
#2085074
06/03/16 10:02 AM
06/03/16 10:02 AM
Posts: 13,581 md
mopars4ever
md
I have small block TTI headers on my car with a mini stater and I removed the plastic terminal extension block on the new starter. I routed the cable between the tubes at the largest opening and secured it to the frame to keep the cable from moving. My cable fit on the starter terminals with a little squeeze. My cable does connect to the starter from the front.
[Re: mopars4ever]
#2085120
06/03/16 11:35 AM
06/03/16 11:35 AM
Posts: 2,592 None
71rm23
None
I was going to enter from the firewall side but my cable wasn`t long enough. I was just going to flip the cable over. I thought the cable gets routed from the firewall. The cable is 3764166, which is 43 1/2" long. But the way the cable ends are and the studs are on the starter won't work unless either 1) Rout the cables forward. Which if was routed forward, the headers are there. 2). There's a plastic "block" or whatever you want to call it that separates the cable terminals, cut that and flip the ends to match the starter. What to do?
[Re: 71rm23]
#2085132
06/03/16 11:48 AM
06/03/16 11:48 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Forget the NOS cable... (I used a 'non-NOS' cable... And fabbed a bracket to keep the cable outta' the Hooker's...
[Re: RSNOMO]
#2085147
06/03/16 12:09 PM
06/03/16 12:09 PM
Posts: 2,592 None
71rm23
None
Forget the NOS cable... (I used a 'non-NOS' cable... And fabbed a bracket to keep the cable outta' the Hooker's... Don't need to use the NOS cable but every one I've seen, the ends are the same. They are all opposite of what the studs on the starter are. Do you have a picture of the bracket? I'll try t get a picture of what I'm talking about
[Re: wesgtx440]
#2085168
06/03/16 12:54 PM
06/03/16 12:54 PM
Posts: 6,224 JERSEY
RJS
JERSEY
That was my post and the help I got from that post was spot-on. Use a small block cable which is longer and then the routing up the fender well will be correct and no interference. Ron
[Re: 71rm23]
#2085182
06/03/16 01:05 PM
06/03/16 01:05 PM
Posts: 13,581 md
mopars4ever
md
I thought the cable gets routed from the firewall. On your car probably but on my car it came down the front past the motor mount. It`s a 77. By the way my cable ends were not opposite on mine. Maybe later cars are different. I have a NOS dodge van cable but it has the extra wires on it like my car. My cable end looks like this (bottom pic) On my wire I could just flip it over.
[Re: 71rm23]
#2085185
06/03/16 01:09 PM
06/03/16 01:09 PM
Posts: 2,094 central texas
krautrock
central texas
i was nervous about the cable on my coronet and running from the front side of the motor to the starter, very close to the header tube.
so i rerouted the cable to run up to the starter from the firewall, as insurance i put some heat shield cloth on the cable but it doesn't seem to even need it the way it is routed.
and yes, the starters are probably sensitive to low voltage, my truck wouldn't start the other day, all cables tight. it had just started fine minutes prior. pulled clamps off and reinstalled. no change.
i figured my starter was dead but i decided to the clean off my battery terminals and the clamps and reinstall them again before doing anything else. started right up!!!
[Re: RJS]
#2085199
06/03/16 01:24 PM
06/03/16 01:24 PM
Posts: 2,592 None
71rm23
None
That was my post and the help I got from that post was spot-on. Use a small block cable which is longer and then the routing up the fender well will be correct and no interference. Ron I have the longer battery cables (small block). I thought the cables went from starter straight back to firewall, around to the battery side. The post you posted tells me it's not. Seems to me that it would be a cleaner look to route it this way and to stay away fro headers or OE exhaust. I'm going to the shop to see if it can be routed like this.
[Re: 71rm23]
#2085269
06/03/16 03:21 PM
06/03/16 03:21 PM
Posts: 3,344 Central TX
roe
Central TX
I wouldn't use the factory style wires. I just redid mine not too long ago to take care of slow starts after it was hot. I went to an audio installation place and bought really heavy guage power and ground wire, 0 & 2 guage iirc, and placed my own ends on. It's that really flexible high quality wire. I measured what I needed and cut it a little longer and routed it the way I wanted it to go. Wrapped the full length in the high heat reflective tubing and this thing fires off crazy fast at the flick of the key even when hot.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: DARTH V8Я]
#2085340
06/03/16 05:14 PM
06/03/16 05:14 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I made my own when I put the mini-starter on my '64 Polara. I did not use FireSleeve on the starter cable, but that is an option. I did use it on the 727 shifter cable in the race car and on the push button cable in the '64 to protect those from header heat. It is easy to make positive and negative cables that are superior to NOS, after all they are made as cheaply as they can get away with.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
