Auto Trans #2084542
06/02/16 11:11 AM
06/02/16 11:11 AM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
On a 2001 Dodge Ram 4X4 with a 46RE is the trans the same as a 2 wheel drive????? What years fit this truck and what no?
Re: Auto Trans [Re: 72 RR DUDE] #2084641
06/02/16 02:58 PM
06/02/16 02:58 PM
Guitar Jones Offline
Except for the O/D unit they are the same.
Re: Auto Trans [Re: Guitar Jones] #2084652
06/02/16 03:18 PM
06/02/16 03:18 PM
Hamburg, Pa.
Hamburg, Pa.
I assume that the over drive unit is in the trans??? Mine is over drive!
Re: Auto Trans [Re: 72 RR DUDE] #2084713
06/02/16 05:30 PM
06/02/16 05:30 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
What is different is the tail housing and output shaft, a 4x4 has the mounting holes because the transfer case bolts onto the end of the transmission. The 2wd goes straight to a slip yoke. The rest of the internals are the same.
You can take the transmission apart and swap over the output shaft and tail housing into a 4wd tranmission to convert it to a 2wd or vice versa.
Re: Auto Trans [Re: 72 RR DUDE] #2084887
06/02/16 10:39 PM
06/02/16 10:39 PM
You only need to swap the O/D unit (essentially just the tailshaft) on a 46RH or 46RE.
