JW Ultrabell with 727 Tranmission and Starter doesnt fit #2082397
05/29/16 05:56 PM
05/29/16 05:56 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I just bought a JW Ultrabell for a BB 727 and installed it on the transmission. All went well, put it in the car, everything bolted up and the starter doesn't fully engage to the ultrabell. There's about 1/2" gap. I can't get the starter flush to the bellhousing.
Anyone run into this problem before and how do you solve it?
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082404
05/29/16 06:14 PM
05/29/16 06:14 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'm using a mopar performance mini starter.
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082409
05/29/16 06:29 PM
05/29/16 06:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
What does the ring gear to starter pinion relationship look like? Close to being correct? Not unusual to have to shim them. The bellhousing kits used to include shims. I had 1/2" worth of spacer in mine and an extension on the nose of the starter.
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: CMcAllister] #2082412
05/29/16 06:34 PM
05/29/16 06:34 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Never thought I'd have to shim this Ultrabell to a 727 transmission.
I believe you and I'm glad you brought that to my attention. Thankyou
I would have though shims for a BB mopar to a TH400 or a powerglide but not for a fixed ring gear attached to the converter for a BB 727. This really ticks me off. If this was the case I wouldn't have even bothered to do the swap.
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082417
05/29/16 06:41 PM
05/29/16 06:41 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I just cut the bellhousing off my powerglide and I too had issues getting the starter in. Luckily I had my big block ultrabell sitting there and all I had to do was file the starter snout with a flat file. 5-6 times out from under the car and it slide in nicely. I used 3 of the 5-6 provided shims to get the proper engagement. Not a big project.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082504
05/29/16 09:20 PM
05/29/16 09:20 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I mocked my new 'bell onto the engine with the torque converter and starter BEFORE I ever mounted it on the tranny. I have read too many stories on here.
I had to file down the nose on my mini starter to get it to fit into the 'bell, so I'm glad I did a test fit.
Master, again and still
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082523
05/29/16 09:51 PM
05/29/16 09:51 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Are you guys filing the front of the starter or the sides? How much needs to be filed?
Is the depth or the width the issue here?
I have TTI headers 1 piece and to get the starter out is rough.
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082535
05/29/16 10:41 PM
05/29/16 10:41 PM
PA.
"Little"John
"Little"John
PA.
If you look at several mopar starters you will notice a big difference in the way the nose is shaped. Mine required very little filing on the champher of the nose with a flat file but I went slowly because it locates the starter because the bolt holes are oversized. On my other adapter plate set-up I used to always go ahead and cut the nose off so I could change out the starters quickly if needed at the track. For this set-up I ran up to the Advance Auto website and ordered a starter for a 1995 Dodge truck and took advantage of the discounts and ran to the store to pick it up. Heck honestly I could have laid on my back under the car to do it but it was easier at 60 years old to climb out an file while sitting on a chair. Sometimes I wish I had a lift. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082536
05/29/16 10:44 PM
05/29/16 10:44 PM
PA.
"Little"John
"Little"John
PA.
To add to this I have the Headmen 1 7/8 headers on my small block and mine has LOTS of room.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: pittsburghracer] #2082698
05/30/16 09:31 AM
05/30/16 09:31 AM
moparx Offline
moparx  Offline
any pics of the interference and the filing required ? what do the shims look like ? just multiples of the "dust cover" shims or something completely different ?
beer
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: moparx] #2082726
05/30/16 11:18 AM
05/30/16 11:18 AM
PA.
"Little"John
"Little"John
PA.
beer
No picture and I took a quick look for my spare shims to take a picture but I'm pretty sure they are in my car trailer. The race car and quad are both in the trailer so its impossible to get to them. Pretty sure this is the part number on Summit so you may be able to see a picture of the shims on JW's website. They are a lot nicer than the shims I made years ago so I stick to these now.
http://www.summitracing.com/parts/jpt-92472/applications/
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082734
05/30/16 11:28 AM
05/30/16 11:28 AM
NC
440Jim Offline
440Jim  Offline
NC
Is this the type of 1/2" thick spacer some are using?
A friend asked me to make this, but then he changed parts so it is not being used.
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: CMcAllister] #2082758
05/30/16 12:18 PM
05/30/16 12:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If it lines up with the starter ring correctly as said
and the nose is all the way in.. I would make up a plate
as a spacer that supports the whole starter...not just the
bolt holes.. but make sure its engaging correctly into the
starter ring first thing... you could weld it to the housing
or just slip it on the starter.. either way would work
wave
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082931
05/30/16 05:46 PM
05/30/16 05:46 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Bought this kit about 2 weeks ago from jegs using it to adapt a JW ULTRABELL to powerglide heres a pic of the shim pack and starter nose extension
I theres actually 5 shims in the pack
Hope this helps
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2082944
05/30/16 06:10 PM
05/30/16 06:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
That's all it is. I used their shim for a pattern and made thick spacers. Actually it was 2 spacers made from 1/4" 6061 since it was easier for me to work with than 1/2 thick material.
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2083074
05/30/16 10:05 PM
05/30/16 10:05 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
UPDATE..............SHIMS DO NOT WORK WITH 727 TORQUEFLITES!!!
What a waste of an hour to put starter up in with shims. Doesn't come close to spinning over the motor.
So it looks like I have to shave the sides of the starter I guess or is the nose of the starter too long? That's the million dollar question.
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2083078
05/30/16 10:11 PM
05/30/16 10:11 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
On mine the pocket ID was too small to fit the nose of an original Nippondenso mini starter. Had it machined larger and all was well, sat flush with the bellhousing no shims required
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: ntstlgl1970] #2083080
05/30/16 10:14 PM
05/30/16 10:14 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I had a feeling this was the issue. I really don't want to take this whole transmission out again.
How much was machined off in the pocket?
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: Sammy] #2083213
05/31/16 01:10 AM
05/31/16 01:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You could measure the snout on the starter then the hole in
the bell... you could drill it in place but will take a bit
of extra work.. you will need a drill bit for the size of
the snout... you will need a bar with that size hole asa
alignment tool... start drilling the hole then grind the end
of the bit off making it a bottoming bit.. then finish with
the bottoming bit.. all the time going through the alignment
bar so your square.. hope you got the idea
EDIT
But make DAMN SURE thats the issue.. and make sure the gap
is the amount of the snout.. minus the smaller area
wave
Re: JW Ultrabell with 727 Tranmission and Starter doesnt fit [Re: MR_P_BODY] #2083286
05/31/16 09:07 AM
05/31/16 09:07 AM
moparx Offline
moparx  Offline
good stuff to know, as i'm up for an A518 in my humpback project. that will require a JW bell, and i was aware of some grinding could be necessary on the block for mini starter fitment [depending on the starter chosen and/or the block], but i was unaware of possible bell issues and starter nose/shim items to look for. thanks for the heads up ! bow how much bell runout is to be expected, and how concentric is the bell id. to the pump od. ? is parallelism of the bell faces ok ? the only JW bell i have ever owned was for a 302 ford to powerglide conversion, and i sold off that stuff around 2001 or so and didn't check it because i had no intentions of ever doing anything with such a combo.
beer
